Glenn9643
Occasionally while using the loader I get a whif of hyd fluid. Seems that I smell it most often when backing away from the pile after dumping. I'm on 20 acres 10 miles out in the country so I'm not smelling something from next door. I've not found any evidence of leaks. Anybody have experience with this? Seems to me that if you can smell it it MUST be leaking somewhere but there's no sign around any fittings and it doesn't show any loss on the sight glass. I haven't had to add any fluid so there are no "spills" that I might be smelling. No obvious problem with the hydraulics; everything seems to be working as it should. Anything to worry about?
