Smart Home Wiring
   / Smart Home Wiring #1
RobS
Super Member
Goshen, IN
None!
I guess I'm really getting lazy... instead of searching the 'net I'm throwing my question out to my TBN buds. Experience tells me I'll get better info anyway /w3tcompact/icons/wink.gif
Here's my question: I'm getting ready to run all the phone, network, video wiring in our house (doing this part ourselves). I've settled on two CAT5 and two RG6 coax cables to each room for the most part. Can I pull all four of these cables into a single work box in the destination room? Can I get faceplate/terminations for all four together?
Also, anyone have suggestions for cable purchase on line? I checked into Crutchfield and they actually seemed reasonable. Our electrician suggested Kirby-Risk locally which I'll call tomorrow.
Thanks ahead of time for the help. I'm firing up my favorite search engine now /w3tcompact/icons/smile.gif
   / Smart Home Wiring #2
Rob,
You can put all of those cables in one box, but it sure will get crowded and tight when you try to terminate them to the plate. You'll probably have to buy a blank faceplate and make your own holes in it to mount the jacks.
If it was me doing it, I'd probably use a DEEP 2-gang box with a blank faceplate that I could mount my own jacks into.
   / Smart Home Wiring #3
Don't pull into a box, but coil the wire up in the wall. The installers I've talked to like 24 - 36" of cable ends left to work with. Use metal mud plates to mark the spot and the drywallers can zip around them. It is hard to get the Quad Shield RG6 into a box without torquing the jacks and cover. Try to avoid outside walls to avoid insulation interference and cold air infiltration. Some people recommend running big conduit to each room for future expansion, but again, don't terminate into a box. If you can access the walls from the basement, the conduit is unnecessary. Run 2 Quad Shield lines to the most likely spot outside for satellite TV and terminate them within an exterior junction box. For some good information on supplies and installation/explaination, see <A target="_blank" HREF=http://www.levitonvoicedata.com/>Leviton Voice and Data</A>. The Leviton products cover the entire spectrum, and are better than the products I saw at Lowes. Make sure the you use Cat5e, not Cat5 for your network. It will give you 1000kbs, which will give you a couple more years before obsolesence. Use it for your phone and doorbell lines also for future capability. Around here this material is sold by Home Depot and the price is reasonable. Most electrical supply houses are now also carrying this, and will carry the odd item you may want the the Big Orange doesn't have. Leviton makes four-jack plugs that can be covered by regular duplex covers. If you do your own terminations get the proper 110 Punch Down, RJ-45 Crimper, and Quad Shield RG-6 Crimper and Stripper tools - they will make it fun.
   / Smart Home Wiring #4
Rob -
I have recently completed construction of a new home and we put in a complete network/phone system, and Direct televison system. Pulling two Cat 5e and two RG6 to every room (several locations in some rooms) is what we did. I have a small router and patch panel that enables easy switching between telephone and computer network for the Cat 5 runs. We used Leviton wall plates and jacks. Try www.futurehomesystems.com for wall plates, jacks, etc. For cable, take a look at www.cablewholesale.com. Finally, www.bestbuy.com is a good source of small routers and patch panels.
Hope this helps!
   / Smart Home Wiring #5
I used a 4 in 1 cable (2 quad shield RG6 & 2 Cat 5E in a 3/4" PVC jacket) that I purchased from IC Intracom [http://www.icintracom.com/catalog4/index.htm]. They are a wholesaler only, but I was able to buy a 500' spool through my work at about $230 including shipping. This is a high quality product.
This stuff is somewhat bulky to run, but you only have to do it once to each room to end up with 2 of each line. Conduit is not needed, since the jacket protects it well. Cutting & stripping the blue jacket requires a sharp blade. The basement looks pretty bazarre with all these big blue cables coming out everywhere. /w3tcompact/icons/eyes.gif/w3tcompact/icons/smile.gif
I terminated 2 boxes & 2 face plates in each room with 1 RG6 & 1 Cat5 in each box. As already mentioned, running 4 to one regular outlet box creates a challenge with respect to space to handle the wires. If doing it again, I might use the deep boxes mentioned & run all 4 to it in order to eliminate the number of plates in the wall. I'll probably use the Leviton type plates (1 cable & 1 phone outlets) available at Lowes or Radio shack. The blank face plates that could be used for 2, 4 , or 6 wires do look pretty slick & are probably available at Lowes also. I have not picked out the junction box that I will use in the basement to bring this mess together yet. /w3tcompact/icons/frown.gif
This is the only time that I've done this, so can't say if this cable is the best. Let me know if any questions... /w3tcompact/icons/smile.gif
Check out this link if you haven't already:
http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=rural&Number=113868&fpart=1
   / Smart Home Wiring #6
You can get faceplates that are modular and will accomodate just about anything. They have 1,2,4,6 and up blanks that take snap in modules for rj11, rj45, RCA, F type, BNC, fiber optic, etc... You can get larger gang boxes that have single face plates. They can accomodate the RG6 without kinking it.
I think you are right about 2 cat5s and two RG6s. You might want to go with more CAT5 and use it for phones as well. It gives you some flexibility in the future.
   / Smart Home Wiring #7
I have a similar installation. I installed mine in '93 and there wasn't nearly as much to choose from then. I have Mod-Tap modular face-plates installed on double wide boxes in each room. I have a Mod-Tap modular patch panel in the boiler room that uses the same modular panels that the outlet boxes do. I used the double wide boxes because I didn't think I could terminate 2 RG-6 and 2 CAT-5's in a single wide box.
I wish I had run more CAT-5. I've used some of the spair pairs in a couple of spots, but I don't like to. Its been really handy, I installed Direct-TV in a couple of rooms and just used one of the spair RG's. If you have any doubts about how a rooms is going to be arranged, run some pull cord so you can pull runs later.
-david
   / Smart Home Wiring
Thanks everyone for the help. As usual, TBN comes through in spades!
<font color=blue>I think you are right about 2 cat5s and two RG6s. You might want to go with more CAT5 and use it for phones as well. </font color=blue>
My thinking was one cat5 for network stuff and the second one for phone. MR, you're suggesting even more. What am I missing /w3tcompact/icons/smile.gif
   / Smart Home Wiring #9
When we wire an office, we run two voice and two data to all locations. The wire is cheap and you'll never have a chance to open your walls again, so run more than you'll need. In your case, the connections are what's going to bite your wallet. So just leave two of the unused wires coiled up in the box.
Also, home security can use CAT5 and you can even run video over CAT5 now, up to 1000'.
I don't see wireless making a strong showing in the home market for a while longer. It is cheap and it works, however, it still has serious security risks that the average home owner(not that you are average) doesn't want to deal with yet. I read a story in the Chicago Tribune recently that said some people with laptops and wireless network cards walked around the loop in Chicago and looked for open networks. They expected to find some, but they found 600! So, I'd avoid it for a while until those issues are addressed.
One more important item. Come up with a naming convention and label all wires now, so you won't have to trace them out later. A suggestion would be:
basement CAT5 00xxx
first floor CAT5 10xxx
second floor CAT5 20xxx
Then label the RG6:
basement RG6 01xxx
first floor RG6 11xxx
second floor RG6 21xxx
This allows for 10 types of wires and 999 connections on each floor. There are probably better schemes, but just develop one and stick to it.
   / Smart Home Wiring #10
If I were you, I'd save the money on all the CAT5 and jacks, then just buy a wirless setup. You would easily be able to get all you need for under $300 and a lot less work to boot.
Check out <A target="_blank" HREF=http://www.linksys.com/> linksys.com </A>
Light Tower (A52377)
PALLET OF JACKS AND STANDS (A53843)
PALLET OF JACKS...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
