smallest Kubota with enough power?
/ smallest Kubota with enough power? #1
mikemike39
Colchester, England, UK
JD 4410
for everything I might ever want to do on my seven flattish acres?
I'd be interested to know what you think - seen a few threads from people who wished they'd bought bigger...
On the other hand some of my land is a little fiddly with trees etc so I don't want too large a chassis - although of course I want loads of power
So the question is - what's the right point - what's the smallest Kub with definitely enough power to do everything someone with seven fairly flat acres might ever want to do??
Cheers Mike
/ smallest Kubota with enough power? #2
Mike -- The answers you get might vary widely unless you give us a better feel for what you intend to do on those seven acres...
Pete
well to start with just cutting, hedgecutting - maybe some haymaking
but I have read that once you get the machine, you think of all kinds of other things you want to do - fencing, trench digging etc etc
I don't mind if some jobs take longer than they would with a bigger machine - I just want to have enough power to actually do anything I might want to do - digging/cutting/moving pulling stumps out etc etc
Not many rocks around so moving really heavy rocks isn't a job I will need to do (I think!)
cheers Mike
/ smallest Kubota with enough power? #4
I love my B7500 and would not want smaller then that.
..just my thoughts...
/ smallest Kubota with enough power? #5
Mike,
Most any of the "B" series tractors will do most of what you want to do and in my opinion none of them will do all that you mentioned. The three things I don't think you will do with a small tractor are hay work, stump pulling and hedgecutting. Haying requires a big machine if you are going to run a baler. You could cut with a small sickle mower and rake but baling is a big tractor job. Pulling stumps is also a big tractor job if you are talking a stump of any size. Now hedgecutting I am not sure what you have in mind. If you are thinking a boom mower like the road crews use, big tractors job.
The most power in a smaller frame will be the B7800 and the B2910. Both would handle 5' mowers, post hole augers for fencing and backhoes for trenching. With a backhoe you will not need to pull stump, you can dig them. Make sure you get a Front End Loader (FEL), best attachment you can invest in.
MarkV
/ smallest Kubota with enough power? #6
Mike -
I see that you've been visiting each different manufacturer forum asking the same question. That's O.K., but it's just a bit cumbersome. Besides, when you ask your type of question in the <font color="orange"> Orange </font>, <font color="green"> Green </font>, or <font color="blue"> Blue </font> forums, you just might get a slightly prejudiced answer for that particular color.
Your basic questions has been asked countless times. If you do a search , you'll find almost everything you're looking to find out. Then, once you have a feel for the brand(s) of machines you're interested in, you could come back to the forums and ask specific questions of those people that own the types you're looking at. /forums/images/graemlins/cool.gif
Just a suggestion to make it a little easier for you. Have fun! /forums/images/graemlins/smile.gif
Hi Garry
I only asked on the red and green boards - I did post about the price of a specific model a dealer offer me on the blue board though /forums/images/graemlins/grin.gif
At the moment I am most keen on red and green..
What I am trying to get to is the most suitable red and the most suitable green (and perhaps blue)
Then, once I am happy I've got the best alternatives, I can work up the pricing and figure out which to get - although as you know, at that point the whole process usually starts over!!!
appreciate the post though, I have done a fair bit of digging in the archives - and I'll certainly keep looking
Anyone have a view on the best red package for me don't hesitate to post
cheers Mike
/ smallest Kubota with enough power? #8
O.K. Mike! /forums/images/graemlins/cool.gif
I didn't realize that you really did have a plan ! It just seemed that you were kind of bouncing around, which happens a lot here - even with some "veteran" members! /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
/ smallest Kubota with enough power? #9
mike: welcome aboard. but where aare these seven flat acres? do u need to move snow? what kind of digging? get my drift? i have 9 acres and have a b2400, for me it is fine. moves tons of snow. cuts fields, moves dirt , does some digging and helps with all kinds of odd jobs. PULLING stumps is not one of its better features, not for the kind of trees and root systems i have here. have pulled some small stumps and removed a few good sized rocks. but for 7 acres i don't think u need to go out of the b series in kubota, or the tc series in N/H. and to cover them all the jd 790. but u know best your needs. GOOD LUCK
/ smallest Kubota with enough power? #10
"Enough power for everything I might ever want to do on my seven flattish acres?"
That is an impossible question that has no answer---ever is as in "ever want" is undefineable. You might choose to build a lake or a skyscraper for all I know. How can anyone but you know what you might "ever" do?
Good luck, hope you find whatever will do what you ever wish to do. /forums/images/graemlins/grin.gif J
/ smallest Kubota with enough power? #12
Actually:
The SMALLEST tractor of any brand that you need, is the LARGEST tractor of any brand that you can afford to buy!!!
/ smallest Kubota with enough power? #13
Our place is a bit over 2 acres, mostly lawn. I finish-mow another 5+ acres, and two or three times a Summer bushhog an acre or two. Snow here is all over the map - some years nothing, others we get dumped on. I have moved triaxle loads of crushed stone, done some digging with the FEL and use the toothbar to groom a sand volleyball court.
My B7500HST with 21HP has been just the ticket. Handy size with enough guts to do what needs done. Since buying it about 15 months ago, it has over 200 hours on it...................chim
/ smallest Kubota with enough power? #14
I'll chime in on the B7500 club. I have 2.5 acres and wanted the smallest, most powerful tractor I could get (within my budget). When comparing FEL, BH and 3pt capabilities, I felt that the B7500 was the biggest bang for the buck on the smallest footprint. After owning it for a little less than a year, I have put almost 220 hours on it. I have pulled some huge stumps, moved mountains of dirt, chipped about 30 yards of mulch, built a 200 foot rock wall, done several logging/firewood projects with it and am in the process of helping a neighbor install a pond right now. The use my tractor has had has been borderline abuse, and it has never even whimpered. Would I like more power at times?.... sure, but my little B7500 has always seemed to get the job done, and in many cases can do it better because of the smaller footprint. I think the most important thing is to buy for what you will be doing 80% of the time and chances are your machine will be able to get by on the other 20%. Good luck in you search. Hope this helps.
Greg
2020 John Deere 470G Hydraulic Excavator (A64553)
2020 John Deere...
Pull Behind Sprayer (A65640)
Pull Behind...
Landhonor 31" Mini Excavator Bucket (A66285)
Landhonor 31" Mini...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
(2) 13.50x60 Tires and Rims (A65640)
(2) 13.50x60 Tires...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
