Comparison Smallest compact tractor for lifting full size round bales with FEL
   / Smallest compact tractor for lifting full size round bales with FEL #11
You need a bigger tractor or a marginal one with extra rear ballast. Anything less and you might find yourself lying on your side some day.
   / Smallest compact tractor for lifting full size round bales with FEL #12
a mx5100 HST 4x4 with LA844 loader is what you need.it will lift the bales off of a trailer with a shredder or other heavy weight on the rear.im assumming youll maining be lifting 4 by 5s an 4 by 6s.wich itll do with ease.itll also lift the 5 by 6s if they arnt to heavy.i traded the above tractor for the 7040 because it was really loaded pulling the hay hauler with 4 5 by 6 an 1 5 by 6 on the loader.
I have the same loader, and I can't see any possible way that I could ever be able to lift a 2k lb roundbale with my tractor, even with my rears filled with 1100lbs of fluid, and a 1400lb stumpgrinder on the back. I just don't see how my loader could lift that much weight. There is no way an MX5100 with a 5' box blade on the back, can lift 2k lbs.
   / Smallest compact tractor for lifting full size round bales with FEL #13
Can you guys with the DK40 lift 2k lbs with only a small implement on the back? That is pretty impressive, I know my little Bota couldn't do that.
   / Smallest compact tractor for lifting full size round bales with FEL #14
I can do it with my Wallenstein on the back
   / Smallest compact tractor for lifting full size round bales with FEL #15
The point is that when I'm out of hay I won't have a bale to use as a counterweight on the rear (chicken and egg problem), plus if I have my shredder attached I don't want to have to take it off, put the rear bale forks on, then when I'm done spend another half hour fighting with the shredder to get it back on. Although, that might be less of an issue with a newer tractor that has telescoping or hydraulic 3pt stabilizer arms. I want to be able to lift a full size (~2000lb) bale off of a trailer with the FEL with only the weight of my 5' box blade or 5' Rhino shredder on the rear as counterbalance.
I burn wood pellets.Each skid weighs 2,000 lbs.My rear tires on my Kioti DK40 HST cab model are loaded with rimguard.I still need a 1,000 lbs rear ballest box as a counter weight to unload.My front pallet forks weigh about 400lbs.also.coobie
   / Smallest compact tractor for lifting full size round bales with FEL #16
What tractor would give me the best bang for the buck
Last January I bought an M4700 (no HST), 4WD w/FEL and canopy in pretty fair condition that will lift 2000 lbs on the FEL and 4000 lbs on the 3pt, and spent $11,500. I consider that a lot of bang for the buck.
Similar tractors on https://www.tractorhouse.com/list/list.aspx?ETID=1&Manu=KUBOTA&Mdltxt=M4700&mdlx=exact&units=metric have asking prices around $16,000. The list price on a comparably configured MX4700 is about $30K, probably about $27K out the door.
So a lot depends on what you care to give up to get a bigger bang. Often if you go used and can "wait for the deal" you can get a lot bigger bang.
You should make up a list of the major manufacturers and the tractors in their line that will meet your minimum spec. Search Tractorhouse, Barlow's, Messicks, Craigs List and auctions for at least a few weeks.
Try looking on Tractorhouse for tractors w/ 4WD, FEL, 40-99HP and a major mfg for $11,500 or less. There aren't a lot.
I've got one.
   / Smallest compact tractor for lifting full size round bales with FEL #17
It sounds to me like your right on the edge of utility sized tractor territory. You could get everything you want, except the HST. I think you'll have to compromise somewhere, whether it be giving up HST (which I understand why you wouldn't want to do) or maybe buying a heavier duty implement for rear weight. I don't know if you can do that with a 5' shredder on the back. Maybe you could get a quick hitch with the new tractor and it wouldn't be as much trouble to change implements?
I think you would find it a lot easier to change implements with the telescoping rear links, so perhaps that could solve a lot of the problems too. Regardless, I would stay away from the Kubota and go with only the heaviest tractors with highest lift capacity like your looking for.
I think your looking for 40hp, is that PTO? I'm not sure the DK40 has 40PTO hp? You may want to look at the DK50, that sounds like a great tractor as well.
   / Smallest compact tractor for lifting full size round bales with FEL #18
now i would not try taking a 2nd bale off the top of another balewith the mx5100.but id unload a single stacked trailer with it with a bale on the rear.
   / Smallest compact tractor for lifting full size round bales with FEL #19
I have a L5740. It will lift our 4 x 6 and 5 x 5 round bales, which weigh between 1200 and 1500 pounds, okay with the loader but can't lift 2,000 pounds centered 2 feet in front of the skid steer mounting plate on the loader so that pretty much puts the Grand L Kubotas out of the picture before even thinking about rear weight. We get seed wheat in 1 ton totes plus or minus 20 pounds because they are weighed and tagged before we get them. The L5740 will strain its guts out to get enough load off so I can skid them along the ground.
   / Smallest compact tractor for lifting full size round bales with FEL #20
For reference, this is the largest loader that Kubota offers in any tractor available with HST. I'd say Kubota could be scratched off your list.
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
9000 (A47477)
9000 (A47477)
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2019 Deere 550K (A53317)
2019 Deere 550K...
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
2013 John Deere 350G LC Hydraulic Excavator (A56857)
2013 John Deere...
