Smallest 4WD JD tractor with heater cab...
   / Smallest 4WD JD tractor with heater cab... #1
DEWFPO
"Up High in the Rockies"
2009 Bobcat Toolcat 5600 D
Can someone tell me what the model # is of the smallest 4WD JD tractor that you can get a heated cab? I need ~30HP or better. Turbocharged is even better if available.
Thanks for the info.
DEWFPO
   / Smallest 4WD JD tractor with heater cab... #2
3000 series. I think the 3120 is 29hp, next up is 3320 33hp then a 3520 and a 3720. I don't know their hp but they offer a cab. JC
Thanks much.
DEWFPO
   / Smallest 4WD JD tractor with heater cab... #4
I think the 3120 thru 3720 share the smallest frame size offered with a cab. The 3720 is turbocharged and intercooled. 37 PTO HP give or take. Great small frame tractor with a bunch of turbo'd torquey HP. Wish I could have one.
   / Smallest 4WD JD tractor with heater cab... #5
DEWFPO
The 3520 is turbocharged too.
   / Smallest 4WD JD tractor with heater cab... #6
DEWFPO
Here is a link to the John Deere cab site:
John Deere : ComfortGard™ Cab Tractors
The smallest one is the 3320 with a cab. And they are all standard 4wd.
3320 - 32.5hp
3520 - Turbo 37hp
3720 - Turbo 44hp
All the same frame - pick your power level.
D.
   / Smallest 4WD JD tractor with heater cab... #7
I saw an X series 4x4 tractor, can't be more than 24 hp in a John Deere dealers showroom yesterday. The cab was really sharp and extended to the back like a bowed living room window. Comes with a heater also. List was 3995 plus about 400 for shipping if bought through the parts counter.
The X frame series is smaller that my 4110. Curtis builds the cabs for Deere.
Thanks for all the information folks. I'll check into them all.
DEWFPO
   / Smallest 4WD JD tractor with heater cab... #9
There are some good resources on here. One of the real questions you need to ask is if you need AC. Cabs and heat are one thing, AC is another.
What do you plan on doing with this tractor?
D.
   / Smallest 4WD JD tractor with heater cab... #10
In some situations a cab without AC is just a greenhouse!
Sincerely, Dirt
ps. I'm not responsable for anything I say.
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
Toro Z Master Mower (A50324)
Toro Z Master...
Avco / New Idea Hayrake (A50515)
Avco / New Idea...
UNUSED TOPCAT QUICK ATTACH HYD 4N1 COMBO BUCKET (A51244)
UNUSED TOPCAT...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
