small welder and pressure washers
   / small welder and pressure washers #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
I was at walmart today and went to buy a pack of welding rod, and noticed my local store no longer has the little campbel hausfield 70a stick or flux welders. Is this just my store/ or have they stopped carrying them?
I'm actually thinking of getting one o fthe little flux jobs .
Also.. i notice that walmart now has a small 2000psi brigs powerd pres washer for 199$.. not a bad deal!
Soundguy
   / small welder and pressure washers #2
Soundguy
My local store has the welder, but no pressure washer. The price is a great deal....
   / small welder and pressure washers #3
Soundguy
That sounds like the little pressure washer I bought at Walmart last summer. It does a pretty good job washing down the ATVs, house and cars. The pressure isn't so great I have to worry much about peeling paint with it.
   / small welder and pressure washers #4
My little 90A HF wire welder is still working great ... they have them all day every day as far as I know. Though, I know it's not fashionable to own one.
   / small welder and pressure washers #5
Wow! Just got an email coupon for the HF welder ... $89.99 this week. Great price for all the use (torture) I've extracted from it :)
Hmm.. I've got a karcher 1750 psi electric unit.. and I have no problem stripping paint with it if I get the nozzle too close..
Soundguy
   / small welder and pressure washers #7
Soundguy
Mine will strip paint if you get the wand to close to what you are pressurewashing, when I first got it I inadvertently etched the 4X4 PT post on my porch. When you maintain a good operating distance and have the wand adjusted right those accidents don't happen as often. I've used some industrial models that would strip paint off a car at quite a distance, this one doesn't have this problem.
I thought about getting one of the Karcher units, and almost bought one before Walmart started carrying this model. The gas engine makes it bery handy to wash down the vinyl siding on our house, as I don't need a long extension cord. The water hoses are enough stuff to have to keep feeding as I work my way around.
I agree. I think that even though i have a 1yr old karcher 1750 psi unit.. I may still get the 2000 psi gas powered unit.. just because.
Soundguy
   / small welder and pressure washers #9
Soundguy
The only complaint I have with it is the size of the tank requires frequent refills when you are doing a big job.
1994 GMC SIERRA C3500 DUALLY TRUCK (A51247)
1994 GMC SIERRA...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
