Buying Advice Small Tractor Purchase Advice
   / Small Tractor Purchase Advice
I've been shopping used, and there just isn't much availability around here. It seems that whatever I find that I want to look at is gone by the time I even call on it.
I'm good with used, too, but my wife wants new, so there is a warranty, so that is a consideration, too.
I understand completely. I am a Dodge man, and won't look at any other truck, but I won't be going back to the dealer I've used the most. I found one with better service. I need to go chat with some more dealerships for tractors, but I'm already leaning away from Deere. The closest dealer was odd. Couldn't understand that I didn't know what I wanted or needed yet and was asking questions for a reason. Across the highway was a Kubota dealer, and the salesman there took a lot of time with the floor models and brochures pointing out features. He also offered to get contact information for people that bought similar equipment so I could ask them questions. I didn't, because I don't want to intrude on people, but he was very helpful for something that costs less than good used pickup
   / Small Tractor Purchase Advice #13
There are no big HP needs here, just for the post hole digger. Snow removal also is a consideration. In terms of size, I'd go small, but not the smallest. I'd put you in 25HP, with a mid mount mower, FEL, and rear blade. A rear blade is relatively cheap and can be used for grading and snow removal, much better than the FEL at both. Your tractor should be small enough for a MMM to work well and have maneuvering room.
Brand wise you have choices. Look at everything around you. John Deere has the 1023e, which seems a little small, and the 1026R, which is a very nice sub compact. A little bigger and you're looking at the 2 series for JD. Kubota has the BX series, very good and solid little tractor. Again, you can go a little bigger to the B series. Kioti has the CK25, but I don't think there's a MMM for that right now. They also have the CS2410, and the CK2510, both of which have a MMM, basic SCUT there, but nice capacities. LS, New Holland, Mahindra, and some others have some options too, but I don't know a whole lot about their SCUTs.
Price is another consideration, decide what you want to spend, and look accordingly.
   / Small Tractor Purchase Advice #14
There are a couple of sayings on this board that I've learned are true.
Pick out a tractor and then buy the next size up, you'll never say I wish I had a smaller tractor. I was looking at the Kubota BX series initially, but decided to get the B2920 with the MMM. If I had to do it again, I would get the L series Kubota with a finish mower, mostly because the FEL Loader capacity is smaller than I need on the B2920. With land there are plenty of uses for a tractor, so while you may have some initial projects in mind that list will grow.
The other saying is Buy once, cry once. Tractors last a long time, I've had mine 4 years and have about 150 hours on it, so it should last a lifetime. A few thousand dollars one way or the other over 20 years doesn't make much difference so try to imagine day to day life 5-10 years down the road.
I do worry about going too big. We are only on two acres, so once the landscaping and fencing is done, the only real need is for snow removal and lawn care. I do think that the 25 HP range is sounding good. Originally I though about the BX18, but now I'm thinking it might be too small
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
40 ft. Shipping Container (A55973)
40 ft. Shipping...
Enclosed Trailer (A56859)
Enclosed Trailer...
2000 INTERNATIONAL 4700 (A58214)
2000 INTERNATIONAL...
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
