Planters small tractor or 4 wheeler
   / small tractor or 4 wheeler #1
luckyme2010
Bronze Member
mobile alabama
mahindra5530 4x4
i have a 1 row jd 71 planter and a 55 horse 4x4 tractor.so i was thinking why not get a small 18-20 horse tractor nothin fancy just for pulling the planter around or i already have a 450 big bear 4 weeler yall think that would pull the planter.what do yall think?
   / small tractor or 4 wheeler #2
Depends a lot on how often you'd need to pull the planter with it. Once or twice a year for a while maybe, no problem. I think much more than than will be hard on the clutch and/or drive belts on the ATV. In spite of all the bottom plows, disks, and such implements seen in magazines for ATV's, their drive trains aren't really built to handle much in the way of steady, heavy pulling. I have a Polaris 500 EFI with auto tranny and I wouldn't want to pull heavy loads with it very long or very often. It would do it, but I'd pay for it in the long run with expensive repairs. Not worth it.
   / small tractor or 4 wheeler #3
I'm with picker on my answer but saying that I have a big Tuffline Disc that I pulled with my old Honda for years, and my Ranger for a couple (that was much better) 40 horses vs. 14 or so. But the disc is really to heavy. But a planter should be easier on the big bear than that big old disc. Just use low gears and don't run it hot. And only a few times a year.
   / small tractor or 4 wheeler #4
Tractor --200% sure. The ATV will destroy the clutch and transmission possibly the axles and CV joints.
But, why get a 2nd small tractor when you have one already?
i have the tuffline disc i used to use with the 4 weeler but it was to much for it i worked but man would it beat you to pieces i would have to redesign the planter for a ball hitch since its set up for 3 point unless they make somethin that will hook to the weeler i dunno starting to sound like a bunch of jerry rigging lol wish i could find a 18-25 hp tractor seems like the used ones are as much as new ones
that tractors to big for a 1 row planter i think a smaller tractor would give me better control its a 5530 mahindra 4x4 the one i have its like dragging a stick behind a abrams tank
   / small tractor or 4 wheeler #7
I have a 500 Honda Rancher. It pulls a 1 row 71 planter very easily. I believe it would pull 2 and possible 3. Planters pull easy so long as they are not no till . The issue is the the lift. The 71 needs to be out of the ground on anything but a gradual turn. I purchased a tool carrier for mine. My planter has double disk openers and I would expect the knife type openers to pull somewhat harder. Part of the reason for using my 4 wheeler as opposed to a tractor is; . Access to some out of the way clearings/plots.
hmm tool carrier didnt think of that of that mr booth your gonna be my new buddy on here hope your patient i always have questions lol i thought about the having to lift it for turns think ill try it mine has the double disc openers and i used the weeler for while pulling a 16' tandem trailer loaded with rr ties and it didnt have a problem with that it wont be used to much maybe 5 acres total of pullin the planter next year im gettin 50 acres of pines cut to open my fields back up ill get bigger planters when the trees are gone
Kolpin DirtWorks ATV 3-Point Hitch System Steel Black WHS03E
this looks perfect
7 reviews - $600 new - 5 stores
   / small tractor or 4 wheeler #10
Sounds like a one-time thing. I'd rent a small tractor for a day or two and be done with it. Muuuuuuuch cheaper and easier.
International 5488 2wd Tractor (A52128)
International 5488...
(4) 3 PLUG VALVES (A52472)
(4) 3 PLUG VALVES...
(INOP) CATERPILLAR 416B BACKHOE (A50459)
(INOP) CATERPILLAR...
TAYLOR TDF-60S STRAIGHT MAST FORKLIFT (A51242)
TAYLOR TDF-60S...
2021 ASV POSI-TRACK RT-120 FORESTRY SKID STEER (A51242)
2021 ASV...
Case IH 8610 Tub Grinder (A50514)
Case IH 8610 Tub...
