Small towable graders?
   / Small towable graders? #1
Joel/ak
Platinum Member
Bobcat 324
Anybody have luck with this kind of set up?. Our road is about a mile long and getting rough.
I've done the back dragging with the fel and used our back blade. It works to certain degree.
A few spots I gotta haul gravel in. Old railbed so the ground is solid.
   / Small towable graders? #2
Boy, a mile long I would at least have a land plane. My drive is only 200 feet so the DR grader would probably be enough for a yearly dressing.
   / Small towable graders? #3
Tractor time with time has a good videos on them. There is another guy from another channel that appears with him that apparently is the “grader” guru
   / Small towable graders? #4
York (the York Rake Company) has a series of rakes with drop down blades.
I have a 7 footer. Works OK if the road has enough moisture.
   / Small towable graders? #5
It is hard for me to believe a ground contact implement weighing 168 pounds, with some weight supported on two tires rather than ripping the road, will accomplish much.
This thing does NOT have a integral rear blade to pull material. It is just a light scarifier, which will bounce.
Greetings from SW MI
New here. My name is Joel and lived in SW MI for about 10 years now. We have a little bobcat 324 mini and a Massey Ferguson 1705 over glorified lawn mower.
Consider a Land Plane or Landscape Rake towed by your truck.
Bobcat 324 Compact (Mini) Excavator
https://www.bobcat.com › ... ›
324 Key Specifications ; Horsepower. 13.9 hp ; Operating Weight. 3,571 lb ; Bucket Digging Force. 3,620 lbf ; Maximum Reach at Ground Level. 14 ft ; Width. 38.6 in.
Massey Ferguson GC1705 Dimensions​
Subcompact Tractor
Wheelbase:57.1 inches
145 cm
Length:97.6 inches
247 cm
Width:47.25 inches
120 cm
Height (ROPS):72.8 inches
184 cm
Shiping weight:1433 lbs
650 kg
Ground clearance:6.7 inches
17 cm
I've done back dragging with the fel and used our back blade. It works to certain degree.
Tractor capability is more closely correlated to tractor weight than any other single (1) specification.
The larger wheels and tires on heavier COMPACT category tractors provide more tractive power pulling ground contact implements and logs, pushing a loader bucket into dirt and pushing snow. Larger wheels and tires permit heavier tractors to bridge holes, ruts and tree debris yielding higher operating speed with less implement and operator perturbation.
   / Small towable graders? #6
It is impossible to make worthwhile implement recommendations without knowing your current tractor brand and model.
1. Click on your "illuminated" screen name in upper right corner.
2. Click on SETTINGS in drop down box.
3. On left side of screen, click on ACCOUNT DETAILS.
4. Scroll down to TRACTOR.
If you add your LOCATION to your T-B-N PROFILE, so your location shows with every post your author, you will receive responses germane to your operating conditions.
4. Scroll down to LOCATION.
   / Small towable graders? #7
Consider a 880 pound to 2,600 pound Land Plane towed by your truck.
Consider a 400 pound Landscape Rake towed behind your truck.
Now you can make your SUV or Pick Up even more veratile by equipping it with a York Rake. Maintaining that long gravel driveway or camp road just got a whole lot easier. Simply attach the rake to your SUV or Pick Up via the 2" receiver hitch, attach one end of the control box to the electric/hydraulic cylinder, the other to a 12 volt power source and start raking. Unit is 8' wide and weighs 400lbs.
MORE: Landscape Rake or Land Plane for road site:tractorbynet.com
   / Small towable graders? #8
I made a set of gauge wheels for my blade and added wings on the side to keep the spoil from making humps exiting the sides of the blade. Now that I have a hydraulic top link fine grade control and keeping my driveway smooth is easy peasy.
   / Small towable graders? #9
Why does a mile long need a land plane?
   / Small towable graders? #10
This weights 168lbs. That's a lawn mower attachment not a subcompact attachment. I would look into something with more weight. It's also basicly a box blade on wheels. Dont you have a 3pt hitch?
7079 (A39855)
7079 (A39855)
2016 Nissan Sentra Sedan (A44572)
2016 Nissan Sentra...
2018 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A42742)
2018 JLG Skytrak...
2025 Swict 66in Bucket Skid Steer Attachment (A42742)
2025 Swict 66in...
2020 Komatsu PC210LC-11 Hydraulic Excavator (A39234)
2020 Komatsu...
New/Unused 2025 STSD10 Seeder (A44391)
New/Unused 2025...
