Small shock that holds up hood of McCormick/Farmall CT41 tractor
   / Small shock that holds up hood of McCormick/Farmall CT41 tractor #1
HarleyRiders97
Wayne County, Pennsylvania
McCormick CT41
Looking to buy a replacement shock absorber that holds up the hood of my McCormick/Farmall CT-41 tractor. It doesn't hold it up anymore. Any ideas would be appreciated! Thanks
   / Small shock that holds up hood of McCormick/Farmall CT41 tractor #2
I've been known to cut a stick or piece of irrigation pipe to the correct length when that happens to me. If that's not elegant enough for you try buying and installing a new gas strut. Yours is leaking.
   / Small shock that holds up hood of McCormick/Farmall CT41 tractor #4
Take the strut to NAPA or similar. They should be able to cross one
Link-Belt 75X3 (A50123)
Link-Belt 75X3...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2000 Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
2000 Kinkaid 1200...
Elgin Pelican Street Sweeper (A51691)
Elgin Pelican...
1980 Case IH 2wd 67hp tractor (A53473)
1980 Case IH 2wd...
