Small shock that holds up hood of McCormick/Farmall CT41 tractor
   / Small shock that holds up hood of McCormick/Farmall CT41 tractor #1
HarleyRiders97
Wayne County, Pennsylvania
McCormick CT41
Looking to buy a replacement shock absorber that holds up the hood of my McCormick/Farmall CT-41 tractor. It doesn't hold it up anymore. Any ideas would be appreciated! Thanks
   / Small shock that holds up hood of McCormick/Farmall CT41 tractor #2
I've been known to cut a stick or piece of irrigation pipe to the correct length when that happens to me. If that's not elegant enough for you try buying and installing a new gas strut. Yours is leaking.
   / Small shock that holds up hood of McCormick/Farmall CT41 tractor #4
Take the strut to NAPA or similar. They should be able to cross one
   / Small shock that holds up hood of McCormick/Farmall CT41 tractor #8
If you have any Autozone stores where you live, they had a strut section, similar to a wiper blade display. Just match one up and go.
   / Small shock that holds up hood of McCormick/Farmall CT41 tractor #9
You might also like to try a local search for businesses that offer to "Re-Gas" your exisiting gas strut(s).
Often they are mobile units which come to you. Some shops perform 'Gas Strut Re-Gassing' here, also.
Possibly a cheaper option ...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2016 FREIGHTLINER...
2022 PETERBILT PB337 DUMP TRUCK (A52706)
2022 PETERBILT...
2007 Volvo VNL Truck Tractor (A55302)
2007 Volvo VNL...
