Small shiny metal thing bottom of L3800?
   / Small shiny metal thing bottom of L3800? #1
Rail Dawg
What in the heck is the shiny metal thing that sticks out the bottom of the L3800 near where we do our lubrication for the pedals?
It hangs down and is always loose and can be pushed up...
Thanks!
Chuck
   / Small shiny metal thing bottom of L3800? #2
Sounds like you have a male tractor....lol
How about a picture.
   / Small shiny metal thing bottom of L3800? #3
Does the L3800 have a clutch pedal?
Wondering if it's the storage latch.
   / Small shiny metal thing bottom of L3800? #4
Condensation/water escape IIRC
   / Small shiny metal thing bottom of L3800? #6
Kubota calls it the "split pin plug" From the manual:
The tractor is equipped with split pin plug under the clutch housing. After operating in rain, snow or tractor has been washed , water may get into the clutch housing. Check by pushing in the split pin. If water enters into the clutch housing remove the plug and drain the water, then install the plug again.
When I had an L3400, I checked it many times, and never saw a drop of water come out of it.
Informational Lot - Financing (A52748)
Informational Lot...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
Landoll Hauloll (A52748)
Landoll Hauloll...
