small radios for our tractor
   / small radios for our tractor #1
lamanated
Nova Scotia and Zephyrhills Fl
BX2360 JD 425 jd 455
I see some small radios on ebay, with handlebar mount speakers,, but thought someone might have installed something, so what would you suggest,
   / small radios for our tractor #2
I use a noise reducing head phone that plugs into my iphone, I can listen to music and also hear if I get a call or text .
   / small radios for our tractor #3
When I did my Mule upgrade project...
http://www.tractorbynet.com/forums/atvs-utility-vehicles/303313-kawasaki-mule-610-upgrade-project.html
I spent quite a bit of time (over a month) reading reviews of some of those types of radios. In the end, I only wanted to spend the money once, and have something that was going to last, be decent quality and not fail if exposed to the elements.
In the end, we installed a Jensen JHD910 radio with the recommended waterproof speakers and flexible antenna.
Amazon.com: Jensen Radio JHD910 Complete Kit - Waterproof Mini AM/FM/WB/Stereo / 3.5" Mini Speakers Waterproof / Top Side Rubber Antenna - ATV/UTV: Automotive
I bought everything separately, but only because the kit wasn't in stock at that time.
A great little radio, speakers are decent, can plug in an MP3 player and it has weather channels as well. A little pricey, but seems well built. I've thought about putting this system on my GC2300. Granted it is under the roof on my Mule, but it does appear to be fairly waterproof.
Good luck!
NV
   / small radios for our tractor #4
I'd suggest something with an amp. I bought and installed Hog Tunes for my wife's Harley. It's basically a set of handlebar mount speakers with a small amp that connects to the bike battery. She plugs in her iPod and listens all day when riding. I'd think there must be a radio setup for that, but I don't know how much you're willing to spend.
   / small radios for our tractor #5
After installing a pretty expensive radio and speaker set in the cab of my NH 3050 I now hardly ever use it at all. Even with the outside sound reduction provided by the cab I have to turn it up relatively high to hear it well. I mostly use a Howard Leigh ear muff set that includes speakers and plug in a tiny sony radio that fits into my front pocket. I can adjust the sound to a comfortable level and cut out 90% of the tractor noise. Works great for me.
   / small radios for our tractor #7
think i would go with a good tractor radio. going over plowed ground ditches ruts and other rough stuff my radios take a beatting but they still play good after all the abuse.
   / small radios for our tractor #9
   / small radios for our tractor #10
I use a SanDisk Sansa MP3 player with ear buds. I wear hearing protector muffs over those. Beats listening to commercials and I load whatever I want to the player. The player is about the size of a car door fob and I clip it on the inside of my shirt pocket.
SanDisk Clip Sport
Ear Muffs
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
John Deere 648R (A50121)
John Deere 648R...
2008 Ford F-150 Ext. Cab Pickup Truck (A50323)
2008 Ford F-150...
Ford 8N Tractor w/3pt. Buck Saw (AS IS) (A50774)
Ford 8N Tractor...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
