Small Planter - Medium Tractor
   / Small Planter - Medium Tractor #11
70 and 71 are plate planters. 7100 are a different technology. They share very few parts.
   / Small Planter - Medium Tractor #12
You need to decide what you want to plant and are you wanting it on a bed due to low area or want to plow to keep down weeds, if so planter is needed. If not broadcast can be a good option. One thing would suggest you give a thought to if you do broadcast is a field cultivator to do the covering rather than a disk. However if you have disk use it and do not purchase a field cultivator just for that.
As to planters, I have four older Cole Planters on four row cultivator frame now. They are I know over 30 years old and last year planted soybeans as good as you could ask for. Hard to beat their ability to plant about anything. Issue there is if you buy such planters parts are hard to find, no longer making them as far as I know. Their design is very simple to switch plates so you can plan big seed to tiny seed. Easy to change spacing and so forth just need the gears for that. If you can find a set in good condition with plates and chain gears at fair price you will like them. This year moved to one of the JD planters that does use plates and only real advantage I found was they are pull behind over lift with my Cole. Now the new Covington not same design of theirs from years back so I have been told.
I have M6800 Kubota and it handles four rows of planters very easy.
Planters will not need as much seed as you have to put out when broadcasting. When you broadcast and cover you will not get all seeds at a good depth. Some will be too shallow and others too deep but cost of broadcast equipment is cheap compared to planters.
   / Small Planter - Medium Tractor #13
An older Cole or JD in good shape with a bunch of different planting plates will work fine.
   / Small Planter - Medium Tractor #14
ive not done sunflowers with mine but did get a plate for them end of last yr I have broadcast them in the past with great results
I use my 71 planter mainly for corn and soybeans but does have the capability to plant many other, peanuts and sugarbeets require
adapter plates. seen them many times on ebat y for sale and sunflowers require a spacer plate. plates can still be purchased by a company
in illinoise that will make them 15bucks each. but if this is for wildlife they don't care if its in rows I think a planter like the Brillion would work
out for you one of the few that says will plant corn. but in reality have planted just about everything at one time or anther by broad casting,
just depends on what your planting have broad casted and tilled in corn and soybeans works well, for seed like sorghum broad cast and litely
drag in works like a charm mainly depends on how large and area you plan on maintaining. but most smaller seed will require a cultipacker.
as a rule of thumb the larger the seed the deeper the seed to be planted. most plots an acre or under can easily be broadcast earthway makes good broad cast spreader or solo
   / Small Planter - Medium Tractor #15
Just a question - do you have a local agg dealer that rents them? Possibly this time of year they are clearing out their rental stock. Might be worth looking into. I know my local rental place has an older Brillion seed drill they rent out, but that might be a different animal to what you looking for. I mentioned the name as they only rent stuff that works and stands up.
   / Small Planter - Medium Tractor #16
Home They have quite a few options here. Both new and used.
Thanks for all the replies, they are a big help. I am in the process of rebuilding an old McCormick Deering two axle cultipacker that I bought anticipating needing one on deer food plots. I also plan to get a chain harrow. Also purchased another "project" a 12 foot JD disk. I am not a farmer but I grew up working on my grandfather's farm and my wife's family are farmers and give me good advice. From what I've read on planting a dove field and my own experience hunting sunflowers the birds like bare ground. Not sure I could get that by broadcasting sunflowers since they are "throw and grow" I have a lot of weeds to deal with. Always shot a lot of doves over silage fields which were very clean after cutting. Our sunflower fields on the hunt club had that bare ground too and we had some great hunts there so that is what I was trying to do in my dove field. Were the broadcast sunflowers you folks planted for dove hunting or to harvest for seed or wildlife food?
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
2019 VOLVO EC350 EXCAVATOR (A51242)
2019 VOLVO EC350...
2017 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2017 CATERPILLAR...
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
2015 ISUZU NRR 20FT BOX TRUCK (A51222)
2015 ISUZU NRR...
