Loader Small pit on cylinder shaft, can it be polished?
   / Small pit on cylinder shaft, can it be polished? #1
BeezFun
IL
Kubota B2710
Was doing some welding, not paying attention, and made two tiny pits on the cylinder shaft on my dump cylinder. I can mostly just see it, but it is noticeable by carefully running my fingernail over it. Is there anything I can do to polish that out, or do I just wait for the seal to go bad and replace the whole thing?
   / Small pit on cylinder shaft, can it be polished? #2
Take some fine emery paper or steel wool and polish the areas the best you can. Removing the sharp edges will make the seals last much longer. If this is a single acting cylinder you trying to keep dirt etc out as much as keeping the oil in.
   / Small pit on cylinder shaft, can it be polished? #3
Pits or berries? If they are berries from weld spatter I'd take a small chisel and carefully knock them off by hand and then follow up by running a medium to fine scotchbrite roloc disc over it until it passed the fingernail test. Pretty much the same for a pit, cylinders can take a few knicks and not leak if nothing is sticking up sharp to cut the seals.
It's not so big that there's anything to knock off. It looks like a small dark spot where the bright finish of the shaft surface has been discolored. When I run my fingernail over it, I can feel something but can't tell if it's raised or etched away. It just feels like a tiny burr.
Cylinder is double acting. Can I use a small jeweler's file, or is that too harsh?
   / Small pit on cylinder shaft, can it be polished? #6
remove any burs.. then use a stone or fine hone then a rollock disc.. can finish with rubbing compound. get everything round.
if it is a deep pit.. consider brazing up and polishing down. smooth surfaces won't eat seals.. might leak if uneven.. but should be seal friendly if all is round.
   / Small pit on cylinder shaft, can it be polished? #7
400 wet dry sand paper using it wet and you should be good to go. ;)
   / Small pit on cylinder shaft, can it be polished? #8
polish it up with some crocus cloth. If the seal fails, address fixing the rod at that time.
I found a really fine stone in my dad's old tools, about as smooth as a piece of wood. I used that with some WD40 and it almost took the discoloration away completely. Can still feel a tiny irregularity there but it's much better. Hopefully the seal will outlive me. Thanks for suggestions.
   / Small pit on cylinder shaft, can it be polished? #10
Chances are that is just a little depression if it shows up on the fingernail test. Knocking it down with a fine stone should have taken care of any protuding burr, if you can run a fingertip over it without feeling something sharp trying to catch it it should be fine. I'm sure my tilt rams have far worse damage and they don't leak excessively. Plus, they're around 40 years old.
AUGER (A58214)
AUGER (A58214)
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
204549 (A52707)
204549 (A52707)
2020 DRAGON ESP...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
