highvolt1
Just bought the YM 1700 and changed oil. The previous owner must not have changed it in a while because it was nasty. When pouring used oil in another container, I found several small pieces of copper colored metal that came out of the pan. I removed the pan and found a few more small pieces, but everything looked good and tight and I did not see any damage on the rods, bearings or piston skirts. I cleaned and re-installed pan, added oil and it runs fine as it did before I changed oil. It is not down on power and I see nothing out of the ordinary.
In the postings back in 2005 a reader found metal particles but ran the tractor several more hours. After several readers advised him to check things out he carried it to a dealer who found a broken crank. I would expected he would have had more knocking or clanking with a broken crank, but he didn't state that was the case.
Has anyone else seen metal particles and what do you recommend I do?
