Small pedal next to the 4WD shifter
   / Small pedal next to the 4WD shifter #1
gsx750r
Hello everybody,
I'm a newby and not a native speaker. I'm living in Portugal and recently I have bought een second-hand Iseki Landhope 240.
It's working fine but there's one minor problem. Unfortenately the former owner lost the owners manual and since alle the stickers on the tractor are in Chinese I wasn't able to find out what the small pedal right next to the 4WD lever is for.
So if anyone of you could tell me what it is for and how to use it, I would be very happy.
Rob
   / Small pedal next to the 4WD shifter #2
Howdy Rob , I have a 240 also & have used it quite a bit. & Dont know what the pedals for. But I,ve never needed it , & Everything works perfectly. I,m Guessing it Might be a Rear Brake Lock or something. I,d also like to know as I cant read Chinese either. Best of luck.
   / Small pedal next to the 4WD shifter #4
The small pedal is to lock up all 4 wheels for max traction. Only when held down.
   / Small pedal next to the 4WD shifter #5
It is a rear axle diff lock - when pressed it is locked. Front axle is engaged only with a 4wd lever.
   / Small pedal next to the 4WD shifter #6
Best when used while going straight - never on pavement around a corner.
Mike
   / Small pedal next to the 4WD shifter #7
Yep Your all right , I,m used to using My 255 that the 4wd lever is on the left up torwards the inside of the fender . So I wasnt sure which pedal he was talking about .
I Only use My 240 for Mowing & never even looked for the 4 wd lever until I just read this again , & Its right next to the axle lock on the right side just above the floorboard . I,ve never used the wheel lock or the 4 WD on the 240 , So i guess I didn,t care . Btw Way it only locks the rear wheels , Wether its in 4wd or not . :D . Bob
   / Small pedal next to the 4WD shifter #8
I agree with Bob, it only locks the rear for posi-traction. You can try and turn, but the tractor will try and go straight.
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A52748)
2019 Ford F550...
FIRESTONE 20.8R42 REAR TIRES WITH WHEELS (WHEELS FITS GENESIS TG-T8000 TRACTORS) (A52748)
FIRESTONE 20.8R42...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
