Small Pasture Maintenance with your ATV
   / Small Pasture Maintenance with your ATV #1
NTrotty
Texas
Kubota 2320
Anyone using a pull behind mower for their small pasuture shredding? 2.5 - 3.0 acres, very clean, no brush. THinking DR model or the tractor supply offering.
   / Small Pasture Maintenance with your ATV #2
I use a Swisher T44 trailmower behind my atv on some steep portions of my pastures that are unsafe with my tractor. It takes time but it works well. I just set it to it's tallest cutting height to take care of some tall weeds and tall grass areas that are going to seed. They also make a Trailcutter if you have more brush and small saplings to deal with.http://www.swisherinc.com/t44_trailmower.asp
   / Small Pasture Maintenance with your ATV #3
I have a Agri-Fab brush mower with a 12.5hp Briggs engine, pull start. Its a lot like the swisher.
I pull it behind my Suzuki Vinson. No problem whatsoever.
I use it along a narrow path we have between the farm land and trees. The path winds through the tress and is about 3 miles long and 6 feet in width. Due to the tree branches getting the tractor in there would be a pain.
I've had it 3 years and have about 250 hours in use.
I can't say enough good things about how its performed. It has needed some small stuff like broken bolts and a new belt. However, the design is pretty simple and repairs are not difficult (otherwise I couldn't make the fix).
I highly recommend getting one to use whenever the tractor can't fit or the job is simple enough.
MoKelly
2019 HINO 195 16 FT BOX TRUCK WITH LIFT GATE (A52576)
2019 HINO 195 16...
2000 Freightliner FL70, 5.9 Cummins (A52384)
2000 Freightliner...
2005 Nissan Pathfinder SUV (A50324)
2005 Nissan...
JMR Attachments Tree Boom (A50121)
JMR Attachments...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
