Small Pasture Maintenance with your ATV
   / Small Pasture Maintenance with your ATV #1
NTrotty
Texas
Kubota 2320
Anyone using a pull behind mower for their small pasuture shredding? 2.5 - 3.0 acres, very clean, no brush. THinking DR model or the tractor supply offering.
   / Small Pasture Maintenance with your ATV #2
I use a Swisher T44 trailmower behind my atv on some steep portions of my pastures that are unsafe with my tractor. It takes time but it works well. I just set it to it's tallest cutting height to take care of some tall weeds and tall grass areas that are going to seed. They also make a Trailcutter if you have more brush and small saplings to deal with.http://www.swisherinc.com/t44_trailmower.asp
   / Small Pasture Maintenance with your ATV #3
I have a Agri-Fab brush mower with a 12.5hp Briggs engine, pull start. Its a lot like the swisher.
I pull it behind my Suzuki Vinson. No problem whatsoever.
I use it along a narrow path we have between the farm land and trees. The path winds through the tress and is about 3 miles long and 6 feet in width. Due to the tree branches getting the tractor in there would be a pain.
I've had it 3 years and have about 250 hours in use.
I can't say enough good things about how its performed. It has needed some small stuff like broken bolts and a new belt. However, the design is pretty simple and repairs are not difficult (otherwise I couldn't make the fix).
I highly recommend getting one to use whenever the tractor can't fit or the job is simple enough.
MoKelly
Loader with Hay Spear (A50120)
Loader with Hay...
Towable Orchard Sprayer (A51691)
Towable Orchard...
2004 Caterpillar 345B Hydraulic Excavator (A50322)
2004 Caterpillar...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2013 Isuzu NPR-HD 16ft Reefer Box Truck (A50323)
2013 Isuzu NPR-HD...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
