Small leak from Hydraulic filter
   / Small leak from Hydraulic filter #1
MoKelly
Super Member
Jefferson County, Mo, ... about 35 miles out of St
Bobcat CT235, Bad Boy z-turn, Suzuki Vinson 500 and F-150
I performed the 50 hour hydraulic fluid change on Monday on my CT235.
I went slow and steady and everything went well ... got the filters off and didn't make too big of a mess. Nicked my head on the right step once but only drew a little blood.
I put the filters on (made sure the rubber ring came off the old filters and was oiled on the new filters) and hand tightened (per the owners manual).
The only problem I seem to have now is a small leak from the hydraulic filter that is under the tractor (largest of the filters). The leak is small (about 10 drops after sitting overnight) but shouldn't be there at all.
Does anyone have any suggestions? Should I tighten it more (another 1/2 turn with the wrench)?
Thanks for any help.
MoKelly
   / Small leak from Hydraulic filter #2
Yes I would.
   / Small leak from Hydraulic filter #3
I had the same thing. I turned it another 1/4-1/2 turn and it stopped.
   / Small leak from Hydraulic filter #5
actually you had 2 leaks........ one from the filter and one from your head
:D
   / Small leak from Hydraulic filter #7
AND the one in your head will heal itself.......
:thumbsup:
JOHN DEERE BA84 WORKSITE PRO ANGLE BROOM (A54757)
JOHN DEERE BA84...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
New/Unused CFG Industrial QK20R Mini Excavator (A57453)
New/Unused CFG...
2342 (A58376)
2342 (A58376)
2019 TAKEUCHI TL8 SKID STEER (A52709)
2019 TAKEUCHI TL8...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A56436)
LIKE NEW 2023...
