Small Food Plot
/ Small Food Plot #1
tractorshopper
Upstate South Carolina
Kubota BX2380
I've helped quite a few others with various sized food plots over the last couple years. This weekend I decided to put in a small one of my own. Sorry, did not stop to take pics, due to rush with rain coming today, but I have a spot in my back yard kind of on a terrace that overlooks the back of my house. I didn't measure it, but it's probably about 30' at the widest point then narrows as it goes back in kind of a triangular way about another 30-40' back.
First, I mowed down all the weeds in the area. Did this on the spur of the moment or would have sprayed this a few weeks ago first. Then I tilled it a few times with my 5' reverse Landpride tiller on my Kubota L3800. Between tillings, I put down 100 lbs of lime to turn in. I picked out as much grass/weed clumps as I could. Then I spread the deer plot mixed seeds and raked in twice by hand. The area is too small to use my chain harrow. After raking in, I spread about another 25 lbs of quick-lime on top. I also very sparsely hand scattered some 17-17-17. Later, when the plants come up some, I'll sling some more fertilizer out there.
I also planted one strip area exclusively in Sugar Beets. This is not a normal crop around here at all. The place I grew up in Michigan had a Sugar factory, so I'm very familiar with these beets and hunters up there use them to bait regularly. The thing here is that they are not a normal crop, and I'm about certain I'm planting them way too late, but having seen them at the feed and seed store for the first time ever, I had to try. I'll probably put some more out next spring. I bought a 1 lb bag and hardly used much at all. I really just put them in as something to remind me of my old home and what it was known for. Don't know if the beets will mature or not this time around or if the deer will be attracted to the leaves or not either, or if they only like the mature beets. At harvest time in Michigan, you can grab literally tons of these off the side of the roads leading from the fields to the factory as they fall off the trucks.
I chose this spot because I routinely see deer tracks funneling through this area and hopefully, I'll see them stop and feed in the future. Will take pics maybe tomorrow after the rain is gone and post if TBN will let me post them. I've had problems the last few weeks.
/ Small Food Plot #2
Good luck and look forward to your pictures. Food plots are the closest I come to gardening/farming and really enjoy seeing a good cover crop or bean crop come in.
/ Small Food Plot
Been trying to attach pictures for 2 days with no luck. Sorry. I haven't been able to put up pictures for a few weeks now.
Yesterday I went to look at it and there were already some very tiny green spots popping up. I think it's gonna be a good one.
/ Small Food Plot #5
You will find that you have to make your plots bigger;the critters will eat it all before it matures.
I don't go less than a 1/4acre.Food plots will feed you wildlife year round if you plant the right stuff.
/ Small Food Plot #6
I tried a food plot for the first time this year, and knew from others at the hunt club that lime was required. How much I didn't know, or what kind of fertilizer to use (most use the generic 10-10-10). So, also being in SC I sent a soil sample to Clemson (about $15 for basic analysis), and that's my advice to anyone intending to sink time and cash into a food plot. Seems the soil around Manning SC, or at least my hunt club's, has far more than enough phosphorus (the P in NPK) but was deficient in potassium (the K), commonly remedied with potash. You might consider an analysis also, with the added advantage of a number specific goal for the needed lime.
Oh yeah, LB Wannamaker of St. Matthews, SC seems to specialize in seeds for food plots. The stuff I got there (a mix that included clover) came up without tilling (much less use of a seeder), a plus even though I have tilling capacity.
/ Small Food Plot
Thanks NY Birdman and Cisco. This plot is really a simple experiment to see if I can stop the deer while they move through. I live in a rural area with lots of farms around me and surprisingly few deer for so many farms. This food plot is very small as I stated. Still can't post pics, but it is coming up very nicely already.
I just tried to put something in a spot that I periodically see tracks and usually a single deer or two. We'll see how it goes. If this was a hunting property, I agree, I'd want more acreage in food plot. I do that at my brother's property.
Cisco, I live pretty close to Clemson and thought about doing a soil sample, but a general reference for my brother's land was one ton of lime per acre and I usually hear around here that previously unbalanced soil needs 400-2,000 lbs per acre. I went heavy on this little patch (125 lbs or so total), but once again, it's just a tiny experiment. I'm not trying to harvest a crop or put in the best plot ever but I do appreciate your feedback.
I have another property where I may actually do a real food plot when I have more time to hunt and I will want to soil test that and do it right.
/ Small Food Plot #8
Don't apologize for the size of your food plot, as mine is only ~ 1/3 acre. The idea is to give deer something to browse on when they show up for your corn pile and it's empty (deer, squirrels, crows, raccoons, turkeys, etc). That's what I've seen on my novice plot.....lots of munched tops on plants. Helps if you've been dealt an assist from mother nature, in my case a couple of oak trees near my stand. When the acorns begin to drop, life (from a hunter's perspective) gets even better.
