Small Flail Mower: Betsco vs. Woodmaxx
   / Small Flail Mower: Betsco vs. Woodmaxx #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
Later this year I will be in the market for a small flail mower to use with my 1025R in maintaining an acre or so of my property that was cleared with a forestry mulcher recently. The two I have found are from Woodmaxx and Betsco. The Betsco is smaller, and cheaper. For use only a handful of times a year is brand a consideration I should concern myself with? I am open to other companies as well.. just don't want to purchase one from the "avoid at all costs" list!
54" vs. 41"
   / Small Flail Mower: Betsco vs. Woodmaxx #2
Any specific reason you want to mow it with a flail instead of a zero turn now that it's been mulched?
I don’t have a zero turn, I do have a GT235. Saplings and brush regrowth I believe.
   / Small Flail Mower: Betsco vs. Woodmaxx #4
I have a 54” Woodmax on a 22 hp tractor. It’s about 4 years old and haven’t had any issues with it other than a couple broken knives from hitting rocks. Believe it’s quite a bit heavier than the advertised 410 lbs. Delivery carrier estimated 600 lbs after shipping crate removed.
   / Small Flail Mower: Betsco vs. Woodmaxx #5
I have a Betstco standard duty flail mower 48" with the hammer blades, I have not had any problems with it and cuts great,
I have a 25 Hp Subcompact tractor and it hadles it just fine, I have mowed grass to brush up to 3" with no problem.
I would buy it again.
   / Small Flail Mower: Betsco vs. Woodmaxx #6
Not sure I could afford to buy mine again. Think I paid about $1900, it’s now going for close to $2400 😎
   / Small Flail Mower: Betsco vs. Woodmaxx #7
I've had a larger 84" Bestco HD model. It has been great for 2 tractors. Do buy the replacement belts when new as the manufacturer suggests. 1st time flail mower users typically burn up the belts putting the cutters into the dirt. I did 😤☹️
Do inspect the hammers annually. I found a cracked/split hammer and changed it out before it came apart this winter
   / Small Flail Mower: Betsco vs. Woodmaxx #8
Prices have gone up I payed $1200 shipped now the unit alone is over $1700.
Yes i bought an extra set of belts just in case they were a weird size and have them on had.
For my purposes why not use a brush hog? Cheaper and seem plentiful on the used market.
   / Small Flail Mower: Betsco vs. Woodmaxx #10
54" vs. 41"
I have the HD 48' flail with hammers from Bestco 3 years in heavy bush and have not broken it, only issue was crappy belts which I replaced with kevlar.
KSI Conveyor (A53472)
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
