Small engine trouble.
/ Small engine trouble. #1
dodge man
Super Star Member
West central Illinois
JD 2025R
It’s a Briggs 5 hp on an old Troy Built tiller. It was given to a friend and hadn’t run since 1982. We cleaned and coated the fuel tank, took the carb apart and got a new diagram and gasket. I think the carb is called a pulse jet. It starts easy enough and runs ok without a load. Turn the tiller on and you can tell it’s not quite running right. It might run for several minutes or it might stumble and die. It almost seems like if you just move it around in circles with the tiller on the movement will make it stumble some. Put it in the dirt and make it work it slows down and eventually dies.
Any ideas?
/ Small engine trouble. #2
Do you have the B&S engine model number ?
Have you checked for compression ?
Is the spark bright ?
Richard
/ Small engine trouble. #3
Any signs black soot around the head gasket.
The number is 130292. One thing I should add is the engine probably has less than 10 hours on it and maybe less than 5 hours. This guy bought the thing in about 1980 and used it a couple of times and it has sat until he gave it to my buddy a week ago.
I don’t see a sign of a blown head gasket. I sprayed around the carb with cleaner looking for a leak and didn‘t hear a change in the engine note.
/ Small engine trouble. #5
Did you clean any of the carb parts, especially the jets? It sounds like it's having fuel delivery issues, and small engines are especially fussy over partially blocked jets.
I think I got the carb cleaned out good. I shot carb cleaner through all the passages. There was places it was pretty gunked up. The bottom of the fuel tank looked like it had a quarter inch of maple syrup dried in the bottom.
/ Small engine trouble. #7
With an L head of that vintage I would be looking at the Valve clearances since they like to float the valves.
/ Small engine trouble. #9
I have a couple 8 HP B/S of about that vintage ('70 s) on Sears rototillers. Maybe yours have a glass bowl under the gas tank. It has a brass screen. Old gas gum settles in it. I'll bet you already looked there. Maybe a shot of Seafoam will help too. If you get it running you'll have one hellava Pony I think TroyBuit called it.
Cheers,
Mike
Yes it is called a pony. It was something like $700 back then. No glass bowl, it pick up fuel with a long tube into the gas tank.
/ Small engine trouble. #11
The part about movement causing it to stumble makes me think something isn't tight. I'd start it and individually shake every part that's not supposed to move and can be safely shook. If shaking a certain part makes it stumble that's a good place to inspect.
I have done that already but your thought was mine also, I was thinking an air leak. I’m still not sure I don’t have something loose.
/ Small engine trouble. #13
Look at the governor linkages and controls. Make sure they move freely
Yeah, the governor not working crossed my mind. I may have someone else run it while I watch the throttle.
/ Small engine trouble. #15
Do you find that choking it slightly improves things? Or that the main has to be adjusted richer than normal?
I fixed it, mostly. I had a spring at the base of the gas tank the hooks up to the governor in the wrong hole. I took the air cleaner off and when I engaged to tiller I could see the throttle wasn’t pulling open.
To answer that question maybe. It’s running good but not great. I put the tiller in the dirt and ran it maybe 2 minutes. Ran fine. I let it run while I wheeled it to my shop and it started stumbling. It seems like you need to play with the mixture screw to keep it running perfect.
Thanks everyone, the tips help. Egons tip on the governor got me thinking about that.
I think it’s running pretty good now. I put some more fresh gas in it, a little Sea Foam, tweaked the mixture screw a little, and it seems to be running good now. No stumbles or anything.
/ Small engine trouble. #18
One thing I've come across when engine runs great for a few minutes and then not is a plugged vent hole in gas cap... 4 or 5 times now.
/ Small engine trouble. #19
Any more issues...it may just not be worth it.
Hard to beat the $99 predator from HF.
2T Chain Lever Hoist (A66408)
2T Chain Lever...
NEW Wolverine DB-15-84W Snow Blade (A62679)
NEW Wolverine...
Vermeer 604 XL-Series (A62177)
Vermeer 604...
LS MT225E (A64126)
LS MT225E (A64126)
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
