Small engine shaft extension?
   / Small engine shaft extension? #1
POC
Southern Indiana
Mahindra 3215 4x4
After the Tecumseh exploded http://www.tractorbynet.com/forums/general-lawn-garden/382548-tecumseh-engine-question.html I began looking for another motor. I talked to my dad and he said he had a donor from a pressure washer.
It has a different si2zed shaft, which isn't that big of a problem as I can just buy a different pulley. But the shaft is only about 1-1/2" long. I need 2-1/2 to 3". Is there such a thing as an extension? I've been searching, but not able to find anything that looks like it will work.
Any ideas? :confused2:
Thanks,
Patrick
   / Small engine shaft extension? #2
not sure how much room you have but a coupling and a short piece of matching shaft may work...check Surplus Center for shafts and couplings...
Good Luck...and BTW you should include a link to the other thread I have no idea what or where without digging...
   / Small engine shaft extension? #3
I've seen this type of stuff at some of the mini-bike and go-kart sites, might puruse them.
I thought about that, not sure how it would work d/t side load from the belt, but this may be what I do.
Thanks.
I found "adaptors" on grainger for changing shaft sizes, and they would work, but pricey for me at ~$60. But may be the way I go.
I also thought about having a machine shop mill me a piece with a hole the same size as the bolt that fits the end of the engine shaft and just get a longer bolt the same size and add it to get the right length.
Thanks everyone.
   / Small engine shaft extension? #8
I'd be worried how that extension going fasten to the shaft. Set screws will never do it or be safe. If you're going to put an extension the crank - Don't.
I'll have to get some pics tomorrow. I'm at work right now.
It's a vertical shaft and the pulley slips on the shaft and has a set screw.
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2013 E-One Apparatus Rescue 95FT Ladder Fire Truck (A51692)
2013 E-One...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2020 Chevrolet Tahoe SUV (A52377)
2020 Chevrolet...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
2004 Ford F-250 Service Truck (A53422)
2004 Ford F-250...
