Small engine shaft extension?
/ Small engine shaft extension? #1
POC
Gold Member
Southern Indiana
Mahindra 3215 4x4
After the Tecumseh exploded http://www.tractorbynet.com/forums/general-lawn-garden/382548-tecumseh-engine-question.html I began looking for another motor. I talked to my dad and he said he had a donor from a pressure washer.
It has a different si2zed shaft, which isn't that big of a problem as I can just buy a different pulley. But the shaft is only about 1-1/2" long. I need 2-1/2 to 3". Is there such a thing as an extension? I've been searching, but not able to find anything that looks like it will work.
Any ideas? :confused2:
Thanks,
Patrick
/ Small engine shaft extension? #2
not sure how much room you have but a coupling and a short piece of matching shaft may work...check Surplus Center for shafts and couplings...
Good Luck...and BTW you should include a link to the other thread I have no idea what or where without digging...
/ Small engine shaft extension? #3
I've seen this type of stuff at some of the mini-bike and go-kart sites, might puruse them.
I thought about that, not sure how it would work d/t side load from the belt, but this may be what I do.
Thanks.
I found "adaptors" on grainger for changing shaft sizes, and they would work, but pricey for me at ~$60. But may be the way I go.
I also thought about having a machine shop mill me a piece with a hole the same size as the bolt that fits the end of the engine shaft and just get a longer bolt the same size and add it to get the right length.
Thanks everyone.
/ Small engine shaft extension? #8
I'd be worried how that extension going fasten to the shaft. Set screws will never do it or be safe. If you're going to put an extension the crank - Don't.
I'll have to get some pics tomorrow. I'm at work right now.
It's a vertical shaft and the pulley slips on the shaft and has a set screw.
/ Small engine shaft extension? #11
Get a double pulley in a Browning (tapered) hub setup and use the bottom belt grove. The taper lock hub will stay on quite well and you should be close to where you want to be distance wise. Just make sure the taper comes into the pulley from the bottom so that you can get at the bolts.
Thanks, I'll look into that as well.
Got the motor mounted today. That was really worrying me since part of the bolts that hold the motor on also hold some of the guards and stuff underneath. I had to put the motor on "backwards" as in, the neat little swoopy "hood" part is not pointed towards the front. I don't think it will make much difference in my mowing speed. Still have to do something with the shaft, but I'll get to that.
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
213064 (A64276)
213064 (A64276)
2019 KENWORTH T680 (A65643)
2019 KENWORTH T680...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
72in. Skid Steer Bucket (A65640)
72in. Skid Steer...
