Small diesels - how much maintenance?
   / Small diesels - how much maintenance? #31
One thing that some people never learn is how to do things in moderation. Either is one of the things that MUST be done in moderation. Just a little to much and that small amount is really WAY to much. Of course, there are defiantly some engines that you CAN'T use either on at all, such as engines with glow plug and preheaters.
   / Small diesels - how much maintenance? #32
Here are a few places that show ether injection on new diesels. One is on a 50/60 class 8 Detriot Diesel, one is on heavy equipment with a Cummins and the middle one is a place that sells ether injectors.
Detroit Diesel 50/60 series engines
Page 6 DDEC-controlled automatic ether starts to –30º F Detriot Diesel
Here is one place where you can buy a ether injection system for a diesel. Quickstart
Here is a heavy equipment Cummins that has ether injection. Hitachi
   / Small diesels - how much maintenance? #33
Jerry, I hope you don't think I was saying that you are wrong. I was only wanting to tell that most people seem to have that ole' theory that "if a little is good; then a more will be better." /forums/images/graemlins/blush.gif That seems to be the issue with the people I know who have used ether with bad results. Sorry if I came across differently.
   / Small diesels - how much maintenance? #34
Dargo,
Not at all. Many people have used it and shouldn't have, that is one of the reasons some have went to hot grid intake heaters. It's real hard to blow up a engine with a grid heater, even if you use to much. /forums/images/graemlins/grin.gif
   / Small diesels - how much maintenance? #35
I know I'm just a newbie here, but I have a lot of experience with diesels. My father owns and operates an excavating company, so I grew up running and repairing diesels. Even rebuilt a few Macks (237s and a 300 that continues to give us cam trouble) and a IH466.
What I can tell you is that older diesels will start fine with ether. But it has to be applied in moderation. Only enough to start the engine. If the engine revs on ether, a few things can happen: 1) It can run at high rpm with virtually no oil pressure (ie bearing damage) 2) It can easily over rev and tear itself apart. 3) The rings can seize to the sleeves or block due to lack of lube (usually in combination with a staved fuel condition like plugged filters). Worst part is that you don't know if you've given it to much ether until you here it catch and start. If it catches and sounds normal (revs to the throttle control) then no damage has occurred. If it catches and screams beyond any RPM you've seen or heard, call a priest for the last rights. You've just killed it. And the difference between the two is like an extra second or two burst of ether from the can. /forums/images/graemlins/ooo.gif
Also, as mentioned before, never start a diesel with ether when it has an active start aid like glow plugs or grid heaters. Disastrous results will occur.
With all the doom and gloom out of the way, a positive is that we've been starting our older diesels (without glow plugs or grids) for years and years without damage. Some of the old Macks have run every day, started by ether, and have hundreds of thousands of miles, and still run great.
   / Small diesels - how much maintenance? #36
CrashZ,
Everything you said is exactly right.
   / Small diesels - how much maintenance? #37
Leo, I think that's as good an explanation as I've seen; good post.
   / Small diesels - how much maintenance? #38
Thanks guys!
2016 LINK-BELT  235X3 SPIN ACE EXCAVATOR (A50854)
2016 LINK-BELT...
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A50854)
KONE CRANES...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
CAT 312C (A50854)
CAT 312C (A50854)
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50774)
UPDATED INTERNET...
377811 (A48836)
377811 (A48836)
