Small Diesel Engines - Natural Aspiration vs Turbo Charged?
   / Small Diesel Engines - Natural Aspiration vs Turbo Charged? #21
I own a little Steiner with naturally aspirated 3 cyl Kubota. Ventrac "apparently" had all kinds of heat related issues with their similar turbo powered units. Unless I understood it totally wrong, Bobcat had the same problems with early Toolcat Turbo units.
   / Small Diesel Engines - Natural Aspiration vs Turbo Charged? #22
If you don't have turbo you must have volume, but still you get a very large lazy diesel, on the old Mercedes Benz 2636 we had a V10 around 19l engine volume non turbo, used very much fuel and did not move those 26t particular fast....
   / Small Diesel Engines - Natural Aspiration vs Turbo Charged? #23
Turbo are free horse power
   / Small Diesel Engines - Natural Aspiration vs Turbo Charged? #24
I only had one turbo....a 1979 Cabover IH OTR tractor with a 400 hp Cummins Big Cam 6, turbo charged. On farm tractors don't, never have, never will. Only if I lived at high altitude would I even consider one.
   / Small Diesel Engines - Natural Aspiration vs Turbo Charged? #25
Why not?
   / Small Diesel Engines - Natural Aspiration vs Turbo Charged? #26
I used to haul heavy equipment and the dealers like Cat, Volvo, John Deere had me cover the exhaust with a bag or duck tape to prevent the turbo from spinning and causing it to burn out the bearings. But it depends on the direction of the machine if it loaded with the exhaust opening to the front where the air is forced in the exhaust it needs to be covered . But if it is facing rearward you don't need to cover it because the air is not being forced in the exhaust.
   / Small Diesel Engines - Natural Aspiration vs Turbo Charged? #27
I"m curious as well. We have 10s of thousands of hours on our equipment and rarely have any turbo problems...If we do, they aren't horribly expensive and pretty easy to change out.
   / Small Diesel Engines - Natural Aspiration vs Turbo Charged? #28
As a Diesel Development engineer for about 35 years, all I can say is that there is a lot of bad or ill informed information in this thread.
Rather than getting into a pissing match, I’ll leave it at that.
   / Small Diesel Engines - Natural Aspiration vs Turbo Charged? #29
How about offering some generic comments on your personal experience over the years with diesels and turbos? That way it's your personal opinion and no one is challenged. Your experience sounds like it would be very helpful.
   / Small Diesel Engines - Natural Aspiration vs Turbo Charged? #30
The tractors listed in his profile are naturally aspirated.....Hmmm......
2008 STERLING LT7500 SERIES (A58214)
2008 STERLING...
Honda 24hp Brush Truck Pump (A57454)
Honda 24hp Brush...
2004 PETERBILT 330 CAB & CHASSIS TRUCK (A58375)
2004 PETERBILT 330...
Heavy Duty 32in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 32in...
UNUSED AGT INDUSTRIAL STSD10 SEEDER (A58376)
UNUSED AGT...
2005 CHANDLER 500 BBL FRAC TANK (A58216)
2005 CHANDLER 500...
