Small acreage fuel storage - 50 gallon drum of diesel or?
   / Small acreage fuel storage - 50 gallon drum of diesel or? #11
I had a 55gal drum set up with a 12v electric pump, but found that it wasn't enough to feed my backhoe and dump truck for my dirt moving project, so I got a 300gal tank off Craigslist for $200. Around here the suppliers have a minimum of 150gal for delivery.
The least expensive solution would probably be to get a 275gal IBC tote (under $100 on Craigslist) and then find a way to elevate it, rig up a hose from the ball valve, and get an inexpensive nozzle to match. That would give you a gravity feed system for probably $125 or less. If you don't want to elevate the tank, you can get a 12v pump that you can even run off your tractor battery. Here's the pump I got:
Amazon.com: Fill-Rite FR1616 Portable Diesel Fuel Transfer Pump, 12V DC, 10 GPM, 1/5 HP, Plastic Nozzle: Industrial & Scientific
   / Small acreage fuel storage - 50 gallon drum of diesel or? #12
Last year i turned a blue food grade barrel into a fuel station with a hand crank for my 27hp Cub cadet 7275 and my Kubota ZD231 and had to fill it twice last year with mowing and baling 1 time. This year I plan on purchasing a new 75hp tractor for baling. So I went with a 50 gallon tank from Family Farm and Home for $250, then I bought a BOSS 15 gal. p/min Fuel pump on sale for $200. Bolted it to a pallet, and place a used good battery for the pump. I do plan on bolting the battery to the pallet, and then running a cable to the battery that will hook up to my 7 pin trailer plug on my truck to charge the battery when I take it to the field to fill the tractor when cutting and baling hay this year.
   / Small acreage fuel storage - 50 gallon drum of diesel or? #14
I have a trailer made from an old Chevy PU bed. I park it under a "car port" kind of steel roof....keep the sun and rain off it. I have 3ea sealable steel 55 gallon oil drums in it with my pump, outlet filter, and battery. When I need farm diesel, I hook to it, go and get the diesel and bring it home. Whole lot easier and safer than what I originally did and that was to make a sling and load the drums in the back of my PU and unload with my FEL. I checked the hasmat tag requirement and leaving room for air aka fuel expansion, the 3 come in just under the 1000# hazmat tagging threshold.
   / Small acreage fuel storage - 50 gallon drum of diesel or? #15
20 Liter yellow jerry cans in a locking flame cabinet.
I second this. In the US, a 20 liters is 5 gallons. I keep mine in a locked shed, no flame cabinet.
I use 50-100 gallons per year and have no problem at all with 5 gallon plastic "cans". I have 4, which cost less than $30 over the course of a few years.
My armstrong pump works by gravity and has never failed. Of course, every time I have the tractor on a trailer and drive by a station, I stop and fill the tractor...
   / Small acreage fuel storage - 50 gallon drum of diesel or? #16
I saw these mentioned on another forum. Roughneck HD UL Listed Fuel Caddy 30-Gallon Capacity | Fuel Caddies| Northern Tool + Equipment If you can transport this to a filling station and back it might help ???
Same thing but for a lot less.
http://cgi.ebay.com/ebaymotors/30-G...948766?hash=item35def6475e:g:KG4AAOSwhkRWeX~G
   / Small acreage fuel storage - 50 gallon drum of diesel or? #17
Lots of cheaper options than a stationary 100-300 gallon tank if you don't mind handling the containers a lot and possibility of fuel spills while manhandling 5 gallons of fuel in a not so friendly fuel container (CARB compliant type). I think many of the older TBN members are in the boat with me and my bad back and over 60 years of abuse to my body so I opted for spending the dollars on my fuel handling so I have very little to lift or spill. The dollars don't seem like much when you compare to a possible stay in the hospital from a slip and fall or a herniated disc in your back or just a strained muscle and the pain associated with these injuries.
Your option on how you spend your money!!
Thanks everyone. After considering all that has been said, I am strongly considering a used stationary tank. I have a 6' x 6' concrete pad I can bolt it to with some redheads. I may try the 150 gallon minimum my local supplier delivers. I have dealing with fuel jugs and I think I can save some money this way.
   / Small acreage fuel storage - 50 gallon drum of diesel or? #19
8x12 fuel shed I built last year to replace a smaller, older one. 300gal gasoline, 250gal diesel. Tanks were on stands in the older shed, but I put them in the loft of the new one, giving me more room for oil/grease storage underneath in the left bay, and whatever in the right.
I either call a fuel distributor to come fill, or take a few 55gal drums to the local farmer's co-op, fill, and transfer from them to the tanks with a 12v 13gpm "Fillrite" pump. Gravity does the work to fill the vehicle.
I use PRI-G, and PRI-D for fuel preservatives. Gasoline will last several years in a vented tank using it, and in a sealed 55 gal drum, 4-5 years easy. Diesel will last many years even in a vented tank, the PRI is probably overkill.
ry%3D400
That's awesome! I'll look into the fuel preservatives also, thanks.
2015 Ford F-450 Knapheide Service Truck (A44571)
2015 Ford F-450...
2004 Case 621D Wheel Loader (A42203)
2004 Case 621D...
2007 STERLING  L9500 MIXER (A45046)
2007 STERLING...
2007 INTERNATIONAL 8600 (A45046)
2007 INTERNATIONAL...
2011 PETERBILT 365 (A45046)
2011 PETERBILT 365...
2015 GMC Sierra 3500 4x4 Truck (Diesel), VIN # 1GT424E8XFF644967 (A44391)
2015 GMC Sierra...
