Slush worse than bale twine
   / Slush worse than bale twine #11
Slush like that will jam and plug any snowblower ever made. That said, keep the RPM as high possible and blowing at a higher through put will increase the time between jams.
Solid augers like on your blower will jam worse than hollow augers but hollow augers will still jam.
A side chute rotating drum blower is about the only blower that will not plug up with slush.
   / Slush worse than bale twine #12
From what your picture shows - you don't have much slush or snow to worry about anyhow. Twenty eight years using a 3-point blower here. Wet snow just does not blow well. Slush - I won't even try with the blower. It will freeze up in the blower, while you are running, and blow a shear bolt.
If it gets cold - you might stand a chance. BUT - watch out - all that slush will turn to ice and "something" is bound to break if you try to use the blower on frozen slush.
Best to move slush with a front mount plow or a 3-point rear blade.
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
7ft Workbench (A57454)
2016 Komatsu PC360-11 Hydraulic Excavator, S/N A35687, PIN# KMTPC256CGWA35687, Turbo Diesel Engine, (A59076)
2016 Komatsu...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
Giyi Auger (A57149)
Giyi Auger (A57149)
1687 (A58375)
1687 (A58375)
