Sluggish transmission engagement
   / Sluggish transmission engagement #1
jdmcla
Mahindra 3215
Good afternoon all and I hope everyone had a great Turkey day! I messed up and let someone use my 3215 to move some sand and when I got it back today, it is VEEEERY sluggish in both forward and reverse when you let the clutch out. Here's what I've checked: it's not in Low range, it's not in 4 wheel drive, I've tried it in all 4 gears with the same effect. Before I loaned it out, I filled the transmission to the full mark. I'm not sure if I overfilled itor if that would make a difference and I'm not sure how to tell if they just burned up the clutch...I'm just not sure so, any guidance is greatly appreciated!!
No sir, parking break is off, I talked with the person I loaned it to and he said that he used it in Low the whole time they had it. I put it back in High range and it's just not right. It's almost as if the clutch isn't grabbing hold until it starts moving forward and even then, it takes a while to get up to speed. It won't budge if I have the wheels turned at all...it's as if the power isn't transferring from engine to transmission. Is it possible that over servicing the transmission could make this happen?
   / Sluggish transmission engagement #4
If my memory serves me correctly if one puts the transmission in a higher gear and then pushes with the front end loader against a fixed object, if the tractor stalls the clutch may be OK. If it doesn't the clutch could be slipping.
I let people use my tractor on two occasions that did not have tractor experience. Both times trouble when it came back, once the clutch.
   / Sluggish transmission engagement #5
Seems to me that if the clutch was slipping, there would be a smell? Is it a dry clutch or wet?
Good reason why I don't lend out any tool valued at over .50.
   / Sluggish transmission engagement #6
It is a dry clutch. How is your clutch pedal play? There should be about 1" of pedal play on the clutch pedal, before you start feeling resistance.
I appreciate everyones input...there is about an inch of play before the resistance starts in the pedal. It feels as if, when you start letting the clutch back out, it doesn't "grab hold" like it did before...I'm sure this is a no no however, I did engage the shuttle shift lever to the forward position for sh!ts and giggles to see if it would grind or anything...nothing, it went right into the forward position as if the clutch pedal was all the way down. There is no burnt clutch smell at all and you're right, never again will it be used by a "friend"...another crappy lesson learned. The person that used it had years of heavy equipment experience and he said he noticed it a little towards the end of when he had it. This is what leads me to believe that I may have put to much fluid in it. I used Traveller brand Premium universal tractor Trans/Hydraulic fluid. It says that it meets the Mahindra manufaturers specs. I have a really bad creeping sensation that I either put the wrong fluid in the wrong hole (I added it to the resevoir in between your feet on the transmission) or, I added too much or, my "friend" really did do something to it. If it's the first two that are screwed up at least my pride will be the only thing that gets hurt...
   / Sluggish transmission engagement #8
The fill point should be right below the front of the seat, right next to the dip stick.
hhmm...I added the fluid to the hole that is center line on the transmission, just in front of the seat. The dipstick in connected to the cap and the cap says "oil" on it.
   / Sluggish transmission engagement #10
That is where it goes. I changed mine about a year ago and used the Wal-mart brand. I have not had any problems.
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
2021 JOHN DEERE 8R250 LOT NUMBER 193 (A53084)
2021 JOHN DEERE...
Paint Dryer, Briggs 5.5 (A52384)
Paint Dryer...
2022 KMC 21-37-HD LOT NUMBER 177 (A53084)
2022 KMC 21-37-HD...
