Sluggish BX22 HST Pedal
   / Sluggish BX22 HST Pedal #1
RiverV
Bronze Member
Northern Ohio
Kubota BX22, Ford 4000, John Deere B
Last night while looking under my tractor as to what may be causing the sluggish pedal return I noticed that there is a Damper connected to the Hst pedal. All the other linkages moved freely so I'm wondering if this may be the culprit causing the sluggish return. Has anyone checked this damper out before to see if it may be the cause? It's listed on page 75 of my parts book reference part 170.
Damper HST: Part no. K2561-42150.
Dave...
   / Sluggish BX22 HST Pedal #2
I haven't had a problem with my BX. I'll take a look at it. /forums/images/graemlins/confused.gif
   / Sluggish BX22 HST Pedal #3
The damper has a certain resistance to it. So it should be at a certain lb-f. (pounds force)
It is in the manual to what it should be. I think it is in the back to middle on the lb-f.
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2019 PETERBILT 567...
