SLT 1554 running rough
/ SLT 1554 running rough #1
Doug802
I have a 1554 with the 27hp motor and it is running rough. I have tried the chock to try and blow out whatever is in the carb out and have taken the carb off and cleaned out the bowls and changed the fuel filter. What else could make it run rough? It does seem to level out under load of blades turning. Thanks for reading
/ SLT 1554 running rough #2
I hate to answer a post with a bunch of questions, but we can give you a better answer if we have more information.
You say it smoothes out under load. Does it run rough only at idle speed? or does it also run rough at higher RPM's with no load?
If it runs rough only at idle, would you say it is "surging"? high RPM, then low, then high again, etc.? This could be a problem with the governor. Or a vacuum leak if your engine is really sophisticated. If it just runs rough with no cycle of high/low RPM, it could be an idle screw adjustment problem.
When you had the carburetor off, did you remove the adjustment screws and squirt some carb cleaner up in there? I don't know anything about your carburetor, but it's common for them to have at least one adjustment needle screw, and sometimes two or three (one for idle mixture, one for high speed mixture and maybe another to limit the throttle closure at idle).
Post more information when you have time.
/ SLT 1554 running rough #4
I have the gt1554 and i surges on cold starts runs great after about 30 secs. hope you find the problem.
MY CUB Stuff
04 GT 3235 60" deck 81hours
07 GT 1554 49.5 hours
08 cc500 push 5 hours
08 cc4175 trimmer 1 hour
07 Cub steele cart 18cu ft
1998 MP CUSTOMS PRESSURE WASHER TRAILER (A67714)
1998 MP CUSTOMS...
Detroit Diesel 4 Cylinder Power Unit (A64912)
Detroit Diesel 4...
1990 FORD LT9000 HOT OIL TANK TRUCK (A67714)
1990 FORD LT9000...
2006 Ford F-350 4x4 Ext. Cab Reading Service Truck (A66736)
2006 Ford F-350...
2012 Gillig G27B102N4 Low Floor 32+54 Low Floor Passenger Bus (A66736)
2012 Gillig...
11 R24.5 Tires - Set of 2 (A68134)
11 R24.5 Tires -...
