rocco611
I have a 04 B7800 with about 450 hours on it. I mow with it about 4 times a year and use the loader to to move things around maybe once a month at most, it doesn't get a lot of use. I change the engine oil every couple of years. Recently on cold start after setting overnight or longer it takes 5 seconds for the oil light to go out when started at idle. I Changed the oil, replaced the kubota oil filter with a wix . same issue. I have always used 10w30 diesel oil. I checked the oil pressure today with a oil pressure gauge. cold start, after about 5 seconds at idle the oil pressure came up quickly to 55 psi cold then dropped to 22psi after warm up. at 2000 rpm warm the oil pressure is 50 psi. warm restart , oil pressure comes right up without delay. is this something I need to be concerned about? what could cause this? oil light used to go out as soon as the engine started .
