Slow speed when tilting bucket on my Ford 4000 1972
   / Slow speed when tilting bucket on my Ford 4000 1972 #1
Alpagas
Quebec, Canada
Ford 4000
Hello all
After the first snowfall which left us with a good 8 inch of snow up here in Quebec ive been using my tractor a lot moree but its so painfully slow to empty the bucket that its no fun at all. Theres enough fluid in the diferential and to move the bucket up and down the speed is decent at best. Can someone point me to a solution or things i could check just to get a bit more speed.
Thanks
   / Slow speed when tilting bucket on my Ford 4000 1972 #2
Has it always been this way or is it a new problem?
   / Slow speed when tilting bucket on my Ford 4000 1972 #3
Is the hydraulic fluid in the rear milky? if so, water is in the fluid and may be freezing up. I had the same issue on my 4000, and found the piston cylinder was bent. That's the last time I'll let anyone borrow the tractor. Had to have another cylinder fabbed.
   / Slow speed when tilting bucket on my Ford 4000 1972 #4
About a 70% chance the valve needs cleaned,,, spray with some PB Blaster.
A slow bucket when the arms still move at a decent speed almost always points to a valve spool that is not opening all the way.
   / Slow speed when tilting bucket on my Ford 4000 1972 #5
Check for play on the valvelever...valve not opening compleetly ?
Genie 2832 32FT Scissor Lift (A50322)
Genie 2832 32FT...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52748)
2023 New Holland...
2024 AGT KFE-20 2,000lb Electric Forklift (A50322)
2024 AGT KFE-20...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A52748)
2018 Dodge Ram...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
