Slow reverse - 3550 HST
/ Slow reverse - 3550 HST #1
Reggie Fry
Mahindra 3550 HST
Hello Everyone! First time posting here. I have a 2017 Mahindra 3550 HST. The reverse works agonizingly slow. I do not have a shop manual. I'm sure there is a way to increase the travel on the reverse pedal. Has anyone else had this same issue and if so how did you resolve. Hoping to perform this myself rather than loading up the tractor and take it back to the dealer for warranty work. Thanks! Reg
/ Slow reverse - 3550 HST #2
I don't have a 3550, but my 2538 HST is noticeably slower in reverse than forward. And in the low gear ratio (H-M-L) it seems even more pronounced. Might be a "safety" thing.
If your reverse speeds in all 3 ranges are "proportionate", then it may be a factory setting. One thing you might want to try is to look at the reverse pedal linkage to see if it's bound up, or even too loose that would inhibit full engagement.
I'm not saying you don't have a problem, but you're not alone in having slower reverse speeds than you would think would be normal.
Thanks for the quick reply. I'll verify if the ranges are proportional. I definitely expected reverse to be slower but this is almost unbearable. I'll also look at the linkage and see what I can see. Cheers!
2010 Case 580N (A60462)
2010 Case 580N...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
2016 HEIL TRAILER (A63569)
2016 HEIL TRAILER...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
iDrive TDS-2010H...
Case 580 Super M Backhoe (A64047)
Case 580 Super M...
