oughtsix
Bronze Member
- Joined
- Mar 16, 2009
- Messages
- 94
- Location
- Redmond, Oregon
- Tractor
- '58 Fordson New major, BCS 735 & 715
I am tired of tinker toy mowers with little rubber band engines that always break.
I am trying to figure out how to attach this:
to this:
I was thinking of pulling the main shaft from this:
and stick it though the hole in the engine it came out of if I can figure out how to get the darned shaft out.
I was thinking of using one of these:
and a pair of these:
but I am not really looking forwards to trying to grind a slot in a hardened shaft.
Then plump the pump to a couple of these:
Any ideas, suggestions or comments?
The pump is this:
For the wheels I have 7cu in, 15cu in, 24cu in and that pair of torque hubs that I was thinking of putting some 30" tires on.
I have the whole 87 corolla the 83K miles engine came out of. The clutch has only 8K miles on it and I would like to use the clutch to unload the engine when starting. I don't like the bastard carb on the engine and I am looking for an ebay carb to replace it without the miles of emissions vacuum tubes. The ignition looks really sweet and I think it is just a 2 wire hookup!!!! I will have to figure out where the voltage regulator for the alternator resides on the car and wire it using the OEM alternator plug.
Final speed will of course be determined by engine speed (goal ~1500rpm), the displacement of the new old stock twin variable displacement pump is 1.15cubic inches max, the size wheel motors I go with and of course the tire size. My thought is to turn the engine slow to get decent gas consumption and also keep her quiet. My original plan was to find one of the 3cyl 1.0l Toyota engines but this one was free.
Suspension is a given and I am thinking air over hydraulic to soften the bumps.
Blades will be driven hydraulically. There is an output hole on the twin var pump for a piggy back pump or two. I have four custom made independently floating mower decks (3 staggered and a spare) made out of a special grade of vulcanized rubber reinforced with steel and nylon belts meticulously crafted by Goodyear. I will wrap these with steel cylinder to keep them from distorting (~24" dia x ~4" high). Should help keep the decks quiet. I might even venture into flail-mower design as they seem to be able to produce a much higher cut quality than I ever imagined when the correct flails are used.
Input PLEASE!!!!
to this:
The pump is this:
Input PLEASE!!!!
