Slow moving hydraulic remote
/ Slow moving hydraulic remote #1
Orchardman
Hi all
Long time reader, first time poster. I have a 2003 Landini Rex and I have an issue with my hydraulic remotes. I use my tractor in my orchard with my Seppi M flail chopper a lot and something I can't figure out is my slowly responding remotes. The RPMs have to be really high to get it to budge and if I want it to move faster, I have to raise and lower the 3 pt hitch. It has plenty of power and the stats show it having a 13.8 gallon per minute rating at the remote but its so slow its silly. Its not the return, but the going out that is slow on the remote too, if that is a clue to anyone.
Im pretty new to remotes so any trouble shooting advice would be appreciated.
Thank you all so much
Mike
/ Slow moving hydraulic remote #2
You might check the filters external and internal if your machine has them.
Do you know if your pump is actually pumping the rated flow.
Test using a flow meter or do the bucket test. If you can pump 1 gal in 6 sec, you have a 10 gal flow.
Is your return line fully open.
Perhaps your pump is worn and can not produce the rated flow.
Check all your QD for correct flow and operation.
1998 Ditch Witch 3700DD 4x4 Ride-On Trencher (A59228)
1998 Ditch Witch...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
2013 Land Rover Range Rover Sport 4X4 SUV (A59231)
2013 Land Rover...
Hydraulic Liftgate (A59230)
Hydraulic Liftgate...
2017 Chevrolet Express 2500 Cargo Van (A59230)
2017 Chevrolet...
