Slow Leak
/ Slow Leak #1
msb1766
Platinum Member
Guilderland, New York
SC2450 Cub Cadet/Yanmar
I have a slow leak in my rear tire that has Rimguard in it, I can't find the leak.
What is the best way to find the leak?
When I find the leak can I use a tire plug?
/ Slow Leak #2
I am not very familiar with Rimguard so hopefully someone familiar with that particular product will chime in as well.
I am very familiar with leaky tires.
I keep a spray bottle of soap solution handy to help find leaks. Commercial bubble solution is probably the best, but mine usually ends up being a bit of laundry or dish soap and water.
If you have a really tough to find leak, there are commercial bubble solutions at a heat and air supply store such as Johnstones.
Anyway, spray down the tire, including the rim, rim weld, valve stem etc. Then step back and let it sit a moment.
Rotate (drive) and do it again.
Sometimes it takes patience, sometimes it shows right up.
I would think with the fill you should see a damp spot on the tire where the leak is if you parked on concrete or such.
Anyway, keep at it and your leak should show. You can also de-mount, steal your kid's plastic pool and dunk it holding it under and then sit and wait for a while looking for the bubble trail.
We usually go through about 100 dog turds (brown plugs) a year. I like the heavy brown master brand. Plug and go, multiple plugs if needed. This year has been great so far, only about 10 flat tires :)
I am guessing you don't have many flats, and with the fill I would locate the leak, make sure what / where it was and pull the wheel and tire with it marked in crayon or sharpie and take it too a commercial tire shop and have it patched inside.
Most filled tires (especially the old CC fill) they would put in a tube before filling but not sure what the standard is with the rimguard. If there is a tube in there (close examination of the valve stem should tell you but sometimes that is tough) be careful how you evaluate a leak around the valve stem.
Good luck hope this helps.
/ Slow Leak
I found the leak it was the valve stem. took it to the place I get my auto tires
he sells auto and small to large tractor tires also, he put in a metal valve stem
for $10.00.
(2) UWS TRUCKBED TOOLBOXES (A62131)
(2) UWS TRUCKBED...
429782 (A61165)
429782 (A61165)
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
2016 John Deere 1795 Planter (A63109)
2016 John Deere...
(2) BUNDLE OF MISC SIZE USED TIN UP TO 23' LONG (A62131)
(2) BUNDLE OF MISC...
UNUSED WOLVERINE BSH-12-75D HYD BALE SQUEEZE (A62131)
UNUSED WOLVERINE...
