Slow leak, no biggy right?
   / Slow leak, no biggy right? #11
If I was a dealer I would want you and GlueGuy as customers./w3tcompact/icons/smile.gif This is an opportunity to create some good will which can pay back in the future.
Al
   / Slow leak, no biggy right? #12
Are these the same guys that worry about a minute amount of talcum in there drive line, or hyd fluid slightly over serviced,or air pressure a few lbs off???? Geez!!!!!!!!
I'd be flippin' on this one........GET A NEW TIRE-It's a brand new machine.
   / Slow leak, no biggy right? #13
Is Pluging a tire acceptable? NOT
Around here, all tire shops patch a tire not plug it.
They remove the tire from the rim and install a rubber patch on the inside of the tire. Similar to a tube patch. Using this method its a frosty Friday in hell before it ever leaks again.
When you plug a tire you actually have to make the hole bigger. Also there is no way of know where the seal point is. If its at the inside surface its ok. If its the outside surface then you run the risk of tread separation as the air pressure migrates into the unsealed hole.
Say no to plugs.
Winnipeg, Manitoba
2001 BX2200 (26 hrs)
   / Slow leak, no biggy right? #14
Dont know if i would get it or not but,Mister tractor dealer can you guys fix my tire rite or do ya wanna swap mine for that one over yander?
   / Slow leak, no biggy right? #15
Like Glenn said, you paid for new, so you are entitled to new. However, if it doesn't bother you then you could settle for a replug (I'm actually not sure that can really be done), but definitely get some good will credit in exchange. They clearly owe you on this one.
If it were me, I'd go for the new tire, partly on principle, but also to test how they stand behind their product. Delivering a "new" machine with not only a used tire, but one that's been puctured and repaired, really calls into question the dealers practices. They should fall all over themselves appologizing for such a hideous error on their part. You can then decide if you really want the new tire or credit against their conscience. If they give you a hard time, then I think you've uncovered a rat.
Peter
   / Slow leak, no biggy right? #16
Oh for crying out loud. If it was plugged, somebody just ran over a nail or something. Sheesh. It could happen to anybody almost anytime. Sure, the plug was a cheap way out, probably should have patched it. Still can.
As long as the cords are not ripped, that tire is still as good as new. If you want insurance, patch it, and put in a tube.
I've driven plugged tires on a car for 40K miles.
The GlueGuy
   / Slow leak, no biggy right? #17
Go ask any tire shop for literature on plugs. Plugs are known to blow out. Think of being on a slope with your tractor and having a blow out. I had trailer tire recently go doing 45 mph on a state highway and it's amazing I didn't wreck and I thankful no traffic was close becuse I was on both lanes trying to contol the trailer with my full size pickup.
Bluegrass, Pick It Up!
Dealer said he would put a patch in it "free of charge." I chuckled when he said that - I mean "free of charge", duh! I understand that a patch is just about as good as a new tire. I suppose I could have put up more of a fuss to get a new one, but arguing on the basis of principle alone does not interest me. IMO, tire fixed good as new = problem solved.
   / Slow leak, no biggy right? #19
Paul
Let the bad boys deal with the principals.
Good use of common sense.
Winnipeg, Manitoba
   / Slow leak, no biggy right? #20
Please re-read what I posted: I said "patch it and put in a tube".
I'm just trying to point out that a simple (no torn cord) hole in a tire is relatively common, minor occurance. It can be repaired simply and inexpensively. Don't throw the baby out with the bathwater.
Perhaps the dealer was in a hurry (or whatever). I don't see this as a federal case.
The GlueGuy
2003 Big Tex 10PI...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
TICO 510 S/A SPOTTER TRUCK (A54756)
TICO 510 S/A...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
Sterling 9500 (A56435)
Mower King Brush Cutter (A53317)
Mower King Brush...
