Flat Proofing Slow leak in Turf Tire
   / Slow leak in Turf Tire #1
Mrez
Spring hill, fl
96 ford 3930
Turf tire 16.7 x 24 on my 3930. after 2 days she is flat.
I have sprayed soapy water all over the tire, rim and valve stem.. many times, I even put a 1/2 gallon of green slime in the tire and it still leaks!!
Any suggestions?
"there ain't no easy road son"
Johnny Cash
   / Slow leak in Turf Tire #2
Are you sure there's no tube in the tire?
   / Slow leak in Turf Tire #3
I dont think 1/2 a gallon of slime is anywhere near enough for a tire that size.
   / Slow leak in Turf Tire #4
After scratching our a$$es until sore, the persistent kid at farmer's co-op discovered why this implement tire had a slow leak. All the spot welds leaked. I sand blasted and applied J-B weld then all was well. Just to inform this is a possibility.
   / Slow leak in Turf Tire #5
I just tube mine when they leak and carry on. Coat the tube in baby powder before installing , it helps��
   / Slow leak in Turf Tire #6
I put tubes in my tubeless tires. I also found that the wheels (intended for tubeless tires) have quite a few very sharp edges and wire remnants due to the welding process. Without knowing this at first, I was having tube failures with no apparent tire puncture. Sometimes you see rubber bands fitted to wheels to protect the tubes from such damage.
NEW  Ripper Shank (A53002)
NEW Ripper Shank...
378746 (A51573)
378746 (A51573)
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
NEW Woods Reverse Rotation 5ft Tiller (A52748)
NEW Woods Reverse...
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
