Slow hydraulics on a TS2210
   / Slow hydraulics on a TS2210 #1
dhoppe1
My lift arms seem to be moving slower than they did a few weeks ago. That includes up and down. But it is really noticeable when I am lowering the implements. The engine speed does not seem to change this. I have filled the hydraulic reservoir.
Do I have a filter that might be clogged? Anyone know when I could check this?
Thanks in advance.
   / Slow hydraulics on a TS2210 #2
The filter and or suction screen may be dirty. Change the fluid, clean the screen if it has one and put on a new filter.
   / Slow hydraulics on a TS2210 #3
I'm sure you know that there is a flow control valve under the seat that controls the speed of descent on your lift arms, right? Turn the valve handle CW and it slows, and even locks the arms in posiition. The reason I mention it is the fact that you mention the arms are lowering at a slower rate. Not sure what else could cause that.
Bill
Thank both of you. I will give take a look at both if the rain ever stops.
2012 SOUTHERN VAC  130 BBL STEEL VACUUM TANK TRAILER (A52472)
2012 SOUTHERN VAC...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
2013 FREIGHTLINER CASCADIA (A52472)
2013 FREIGHTLINER...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
22ft T/A Enclosed Cargo Trailer (A51694)
22ft T/A Enclosed...
