Slow hydraulics on a TS2210
   / Slow hydraulics on a TS2210 #1
dhoppe1
My lift arms seem to be moving slower than they did a few weeks ago. That includes up and down. But it is really noticeable when I am lowering the implements. The engine speed does not seem to change this. I have filled the hydraulic reservoir.
Do I have a filter that might be clogged? Anyone know when I could check this?
Thanks in advance.
   / Slow hydraulics on a TS2210 #2
The filter and or suction screen may be dirty. Change the fluid, clean the screen if it has one and put on a new filter.
   / Slow hydraulics on a TS2210 #3
I'm sure you know that there is a flow control valve under the seat that controls the speed of descent on your lift arms, right? Turn the valve handle CW and it slows, and even locks the arms in posiition. The reason I mention it is the fact that you mention the arms are lowering at a slower rate. Not sure what else could cause that.
Bill
Thank both of you. I will give take a look at both if the rain ever stops.
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
Miles read : 112,969 (A50323)
Miles read ...
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
2002 Fleetwood Expedition 36ft Motorhome (A51694)
2002 Fleetwood...
7ft Adjustable Scrape Blade (A51573)
7ft Adjustable...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
