Slow B20
   / Slow B20 #1
fishman002
OK. The wheel is unstuck, now the next question. I used the tractor today and it seemed sluggish. It has plenty of power and all of the hydraulics work as they should but it's ground speed is slow. The ambient temperature was around 35 and I was shovelling snow with the FEL. Any ideas?
   / Slow B20 #2
I would change the fluid and filter. Be sure and use kubota fluids....
that would be a start then go to plan B
   / Slow B20
I spoke with a local Kubota service tech and he agrees that the fluid and filters should be changed so I plunked down $253.74 and bouhgt them. I am going to change them Friday.
   / Slow B20
OK Fluid and filters changed but no joy, still slow. Now what?
   / Slow B20 #7
Could the pedal be restricted from moving all the way, or be out of adjustment? By the way, see if the guy will give you back your money for the fluids. Tractors sit outside all the time, why should the oil need to be changed unless you leave the top off the fill hole or something like that.
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
2015 John Deere 8245R MFWD Tractor (A53342)
2015 John Deere...
PAIR OF 5' PIN ON FOLD UP RAMPS (A51247)
PAIR OF 5' PIN ON...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
UNUSED CHERY INDUSTRIAL 10' - 15 DRAWER WORKBENCH (A51248)
UNUSED CHERY...
LMC LOT NUMBER 130 (A53084)
LMC LOT NUMBER 130...
