Slopes and tractor tilt
   / Slopes and tractor tilt #191
I will address going across a slope. I have steep ground and have been considering a new tractor for mowing. I first found my greatest slope. I took an angle finder and a straight 4 foot piece of 2 x 4. I found one spot had an angle of 30 degrees. I divided that by 90 to get a slope of 33 percent. Ventrac and powertrac are the only tractors to advertise 40 percent slope or greater. These are with dual wheels. Steiner only advertises 30 degree slope. the problem is not rollover but oil to engine parts.
Over the hill in Phillipi huh ? My ground is near Lost Creek but I live over 300 mi away. A couple of quick comments:
1) You can't divide 30 deg by 90 and get % slope. A 30 degree slope is over 50% , almost 60%. Percent slope is "rise divided by run." For example a 25 inch rise at the end of a level 2x4 62 inches long computes to be 25/62 = 40%. (roughly 25 degrees.) Thus the Steiner advertisement of 30 degrees is considerably steeper than the 40 % slope you said the others claim. Five or ten degrees at that point is a bunch. That's partly why expressing slope as a percentage is popular.
2) The world champ of mowing steep ground -- bar none -- is the Aebi Swiss made machine. See Aebi Tractors front rear implement carrier steep slopes land care . Snowshoe used them at one time and maybe still do to mow ski slopes in the summer. Those are incredible machines designed from the ground up for steepness. Ones I saw used a Kubota motor BESIDE the operator for getting a low center of gravity. Have PTOs and 3 pt hitches both front and back. In later years they make them in larger sizes too, like 90 hp.
3) Obviously in your situation you have to use 4wd or be hung all the time. I'm guessing one of the mainstream brand 4wd small tractors (Kubota or Deere or Massey) would do well for you and have the added bonus of handling 3pt hitch implements when needed. A problem is that most of them are not designed for really steep ground, as you said. The key is spacing the rear wheels apart and some models are not even adjustable. That may well leave a niche for Steiner, Ventrac, etc.
   / Slopes and tractor tilt #192
Guys, I had to post this.....
I ordered and installed an "inclinenometer" on my Kubota last week. [I'm using % because I have no DEGREE key.] The slopes that had initally concerned me are only 15%. (I had gotten used to them) The ones that made me pucker are 25% and MUST be taken in "turtle and 1st gear". A few times I would sink in a hole and it would go to 30% where I would immediately do the down hill steer manuever. Now that it is installed I will recommend it to everyone.....it's definately an asset and a tool.:thumbsup:
I repeat: A 25% (I said percent) slope is mild by most standards. A 25% slope is around 15 degrees. Most farmers have been over slopes of that steepness and never even thought about it. I never mentioned degrees in my previous comments.
I readily agree that a 25 degree slope (somewhere between 40 and 50%) would be intimidating and probably inadvisable if you were going across it as opposed to up and down. Slopes that steep are usually handled up and down, not across, as I'm sure you know.
I reorganized Boeings post with critical info leading. Look for it.
larry
   / Slopes and tractor tilt #193
[2) The world champ of mowing steep ground -- bar none -- is the Aebi Swiss made machine. See Aebi Tractors front rear implement carrier steep slopes land care . Snowshoe used them at one time and maybe still do to mow ski slopes in the summer. Those are incredible machines designed from the ground up for steepness. Ones I saw used a Kubota motor BESIDE the operator for getting a low center of gravity. Have PTOs and 3 pt hitches both front and back. In later years they make them in larger sizes too, like 90 hp.
Thanks for the link.
Their lead in page says "work safely on 40% slopes". What a terrible advertising error.
larry
   / Slopes and tractor tilt #194
larry
Good catch ! Surely they MEANT 40 degrees not 40%.
   / Slopes and tractor tilt #195
That Aebi tractor is awesome and the slope they're showing it on is definitely 40 degrees, probably closer to 45 (100%). Even dozers can get squirrely working across slopes like that. We would generally keep a berm on the lower side and work it downhill or do it all up and down. We had one operator Old Sy, that worked across a 150 ft loose shale slope so steep that no one else wanted to get on it. Every time it'd get loose you could hear him cussing all the way to the bottom, because he'd have to head it downhill then track it over 1/4 mile around to get back on top. It was so loose you couldn't work it up and down.
You can make a simple slope gauge using a large mechanical drawing type protractor (or reasonable facsimile) by mounting it upside down with a piece of coat hanger dangling from the upper center point. Crude but it works and will give you an idea of your slopes. I did that when first learning to grade many moons ago.
   / Slopes and tractor tilt #196
Why do you says 40% is a ad error? That is about what I'd guess the slope they show on linked page with the front mount fail mower and dual wheels front and rear. Do they show something steeper somewhere? Do you think that is much steeper than 40%? I'm not really experienced at judging grades but they always seem to look steeper than they really are.
   / Slopes and tractor tilt #197
Because they say the product is specially designed to be safe on steep slopes. You dont have to pay premium for safety on a 40% slope. A garden tractor will do that.
larry
   / Slopes and tractor tilt #198
larry
40% slope is about 18 degrees...definitely doable on dry grass and using caution.
   / Slopes and tractor tilt #199
For the degree symbol, hold the ALT key down and type in 0176. For example, 40ー.
However, using these hotkeys doesn't always display correctly on TBN (as above).
   / Slopes and tractor tilt #200
The garden tractor at 40% isn't exactly what I'd call safe. Doable with caution sure but if you find a hole that use to have tree stump in it you suddenly you pick up 10 degrees. 40% is about 22 degrees, tack on 5 or 10 degrees for safety and you are talking about a 50-60% slope. See Slope - Degree, Gradient and Grade Converter for a nice table that goes both ways. I think their ad is correct, 40% slope is all I'd want the liability for. 40 degrees equals 84% slope would you want the liability for that? Let someone take it steeper if they think they can but I wouldn't call it safe for advertising purposes. What does JD advertise as safe for a garden tractor?
(2) PALLETS OF TRAILER JACKS & MISC TRAILER PARTS (A54757)
(2) PALLETS OF...
2015 GMC Terrain SUV (A56859)
2015 GMC Terrain...
2018 ARIENS Zero Turn Mower (A56857)
2018 ARIENS Zero...
Harley Davidson (A56859)
Harley Davidson...
1992 BYQ Boat and Trailer (A56859)
1992 BYQ Boat and...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
