Slope
/ Slope #1
stevewilli
UK, south coast, on a cliff
Better picture of my slope. Any comments on the suitability or otherwise of using the BX2200 to mow this would be much appreciated.
/ Slope #2
The safest way to mow a slope is drive down, back up...
From your profile : <font color=blue>UK, south coast, on a cliff </font color=blue>
Better make sure you have good brakes!!!! /w3tcompact/icons/wink.gif
Billboe
/ Slope #3
Should be fine going up and down the slope. Attached is a photo of me on by B2710 cutting the one of the hills at my shop. I wouldn't try doing it side to side, but its not bad up and down.
/ Slope
I think its an Austrian/Scots pine (Pinus nigra) - they go flat topped when mature (50 yrs this one - planted by a guy called Eric Williams who wrote 'The Wooden Horse' - you've probably seen the WW2 escape film)
/ Slope #8
Steve,
I turn around at the bottom, drive straight up and then turn around at the flat on top and drive down.
/ Slope #9
I suggest you measure your slope with a standard carpenter's protractor available from any hardware store or use a Tiltmeter. Most compact tractors can operate on side slopes of somewhere between 15-20 degrees. It depends on the tread width, surface roughness, turf wetness, travel speed, other equipment on the tractor such as a loader, etc. You can find many other tractor owner comments on this board about their experiences in operating on slopes. Many express a high rise in their "pucker factor" on slopes of 15 degrees or more.
/ Slope #10
I've a slope that goes from ~15° to 20°-25°. However, it's a short run. Now, to get the best cutting, I've got to back down to a tree line and drive up in 1st or 2nd (low range). All of this is done in low range (tractor is a JD 670 with a 60" rear mower). There is a FEL on the tractor...keeps the front end down. That, and slow speeds seem to keep it pretty safe. However, mowing this area takes longer then it did with my old 48" Wheelhorse (12HP)
I've noticed quite a few farms around here (south central PA) where farmers go across slopes (tilling, mowing, etc.) I wouldn't even think about. Reckon most of these tractors can take more tilt then we can.
/ Slope #11
von and steve : those are quite some slopes. do u have weights on the front to keep her down or is the slope not as bad as it looks?
/ Slope #12
Frank,
I bolt two old wheel weights to the front (about 100lbs) they help, plus my rear tires are loaded. I have no problems as long as the rear tire of the mower is also on the ground. (see photo attached of weights)
2019 JOHN DEERE XUV855M S4 CART (A66091)
2019 JOHN DEERE...
2017 JAYCO WHITE HAWK CAMPER (A67714)
2017 JAYCO WHITE...
2011 HUTCHISON CRUDE TRAILER (A67714)
2011 HUTCHISON...
218799 (A65057)
218799 (A65057)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65056)
KNOW BEFORE YOU...
CLUB CAR  CARRYALL 6 (A67714)
CLUB CAR CARRYALL...
