Slop in rear end when changing from rev to forward and back to rev
   / Slop in rear end when changing from rev to forward and back to rev #1
09112
N.E. Oklahoma
yanmar 3810, 48 Allis B
I hope I can explain my situation well enough to be understood. I have a 48 Allis B that I have recently rebuilt, (mostly parts replaced), everything except the differential, which I know nothing about. When I start forward I get a definite slap in the rearend and the same when I start in reverse. There are no unusual sounds when traveling, shifting is normal. Is there a reasonably easy way to take this slop out?
   / Slop in rear end when changing from rev to forward and back to rev #2
Have you checked the center hub, to rim bolts..?? They could be loose causing the problem, but you usually hear a cracking noise along with that.
If that's not the problem, then I'd think the next place to look would be the ring & pinion gears, and on out through the finals.
Ok DJ54, thanks for the suggestions. I'll check that out and just hope the bolts are the problem. I've only driven the machine a couple times in the shop and not really enough to identify many ideosyncrasies.
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
2018 CASE IH 110N LOT NUMBER 219 (A53084)
2018 CASE IH 110N...
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
