Slipping trans
/ Slipping trans #1
The Cub
Cub cadet 1250
What can I do about a slipping tranny on a cub cadet 1250? HELP
/ Slipping trans #3
Filter change? Is it in forward and reverse?
/ Slipping trans
I just changed the oil and filter oil is full and it's when I'm going forward
/ Slipping trans
Is there any way to fix the hydro pump
/ Slipping trans #6
did you purge air from the hydro tranny after refilling ?
/ Slipping trans
How do you purge the air from the pump? Would it not just come out by it self
/ Slipping trans #8
yer manual should have detailed instructions for such...
/ Slipping trans #10
my 149 had some trouble when going forward. The hydrostat handle would also move on its own. it would slow down as i moved forward and eventually end up in neutral. If this is your problem there is a piece that u can tighten up on the linkage
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
Bull Grill (A64127)
Bull Grill (A64127)
LOOK! (A63109)
LOOK! (A63109)
X-Star 300 Gal Fuel Tank (A64127)
X-Star 300 Gal...
2023 Kubota SVL97-2 Compact Track Loader (A63689)
2023 Kubota...
2019 K&K Trailer, VIN # 1K9PE2029KA175462 (A65563)
2019 K&K Trailer...
