Slipping trans
   / Slipping trans #1
The Cub
Cub cadet 1250
What can I do about a slipping tranny on a cub cadet 1250? HELP
   / Slipping trans #3
Filter change? Is it in forward and reverse?
   / Slipping trans
I just changed the oil and filter oil is full and it's when I'm going forward
   / Slipping trans
Is there any way to fix the hydro pump
   / Slipping trans #6
did you purge air from the hydro tranny after refilling ?
   / Slipping trans
How do you purge the air from the pump? Would it not just come out by it self
   / Slipping trans #8
yer manual should have detailed instructions for such...
   / Slipping trans #10
my 149 had some trouble when going forward. The hydrostat handle would also move on its own. it would slow down as i moved forward and eventually end up in neutral. If this is your problem there is a piece that u can tighten up on the linkage
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
2009 Cat 140M VHP Motor Grader (RIDE AND DRIVE) (A50774)
2009 Cat 140M VHP...
Tandem 6 Lug Running Gear (A50774)
Tandem 6 Lug...
NEW HOLLAND TS6.130 TRACTOR (A51406)
NEW HOLLAND...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
