slipping slip clutch
   / slipping slip clutch #1
yanmars
I have a heavy duty Bush Hog brand 6 foot brush hog. This Spring I mowed down quite a few saplings and thorn trees etc. Most under an 1 inch in diameter, some up to 3 inches or so. It worked well. Today when I took it out it would barely cut 6 or 8 inch high grass. When it got into the thicker grass the PTO shaft was rotating slowly. I think the slip clutch is slipping, either that or could the main nut holding the blades on underneath be loose? I have had it to the dealer twice in the last 2 years because the nut came off and the blades came off. I told them to torque it high enough or use loctite or spot weld it. Hopefully it is not loose a third time.
If that is not it and the slip clutch is slipping. Can I just tighten the nuts slowly, say a half turn each and see if the puts more tension on the unit so that it cuts the thicker grass? Keep doing so slowly until the unit functions and does not slip excessively. Thoughts or ideas. Thanks
   / slipping slip clutch #2
I'd check the nut under first...
IF, that is tight, then I'd make sure the clutch plate isn't wore too thin or broken and if good, I'd adjust the clutch for the HP of your tractor...
SR
   / slipping slip clutch #3
The PTO shaft should be rotating at 540 rpm. There should be an indication on your tachometer as to what engine speed that is, usually a little over 2000rpm. Assuming you have an "open" slip clutch, you can mark it so you can see if it's slipping. Just take a white marker and draw a line across the friction disks and metal plates, run it a little, recheck if they are still in alignment.
However, from the rest of your post, I'm inclined to believe that the nut on the gear box underneath the mower is loose - again. There should be a castle nut on there with a cotter pin to keep it from loosening up. It does not appear that your dealer can fix it, I've not had to tighten mine, ever! Do not expect to be able to tighten it by hand with a wrench even with a pipe on the wrench. You really need a big impact wrench to get it tight enough. It may be possible to get an independent car mechanic or maybe a machine shop to tighten it properly. Or, you can also use this as an opportunity for a new impact wrench. HF has some big ones for not much money. Even small compressors will run them, you'll just have to wait while the tank refills between trigger squeezes.
   / slipping slip clutch #4
That is how I set my slip clutchs.
Often questions are asked for advice and then no report back on success, or not. I tried to tighten the large nut under the mower, even my 2 inch nut was not large enough. Put a pipe wrench and cheater bar on, still could not tighten it and it did not seem loose and was not proud of the shaft. Probably would not have enough strength to tighten it what would be needed, I think over 350 foot pounds.
Went to the slip clutch bolts/nuts. I did tighten them all about 1/2 turn. They actually seemed to me to be too loose. Did some light mowing, not in real heavy stuff but it worked well with no slippage. Will try tougher jobs in the future and see what happened. Hoping I am good to go.
   / slipping slip clutch #6
Thanks for the report back. And it does sound like you're good to go. Remember that once a year, to loosen the nuts and let it slip and re-tighten the nuts to keep the plates from corroding.
   / slipping slip clutch #7
"When it got into the thicker grass the PTO shaft was rotating slowly. I think the slip clutch is slipping,"
If you are running the pto at 540rpm the pto shaft should be rotating at the same speed. They are mechanically locked together with the splines. The nut under the gearbox would have nothing to do with that or the slip clutch as they are past the pto.
   / slipping slip clutch #8
That is what I was thinking.....what does the nut or anything else on the cutter have to do with the tractor maintaining the correct PTO speed? It sounds like an issue with the tractor.
   / slipping slip clutch #9
Or as simple as the OP using the PTO shaft with the clutch on the tractor side. If the clutch spins, the shaft spins slower.
   / slipping slip clutch #10
I have a slip clutch on my John Deere 506 mower that I regularly have to play with. I keep it a bit loose to absorb shock, but too loose and you never see it slip, but you'll smell it! Then can get wicked hot very quickly.
But thank for reminding me: its time to loosen mine too.
2012 Cadillac SRX SUV (A50324)
2012 Cadillac SRX...
1999 Toyota Tacoma Pickup Truck (A50323)
1999 Toyota Tacoma...
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
