Slip scoop for XUV
   / Slip scoop for XUV #1
jcmseven
western NC
JD 2320; 4520
Fellow Posters:
I am looking for a slip scoop (aka Johnny Bucket) to fit onto my XUV Gator for some light duty hauling, etc. Does anyone know if one of these is made yet?
John M
   / Slip scoop for XUV #2
you mean a bucket for the front ?? if so i seen some for atv's so i would say that they should have some for the utv's too if not one could be made very easy.
Tommy,
Yes, this is what I am looking for. The Bobcat has a nice one, as does JD for the X series tractors. But there are not any premanufactured ones, that I can tell, for the JD Gator. I am still looking. These things are really handy, especially if you do not want to get out the tractor, or have an area too tight or soft to safely access by tractor.
John M
   / Slip scoop for XUV #5
I have a John Deere Gator HPX 4x4 which has to be one of the most handy pieces of equipment ever. It has a 72 inch front blade which is great for snow and also light grading. I'm looking for an attachment to add to the blade to make it a scoop for loader work in tight spaces. Deere makes such an attachment to add to front blades on their garden tractors but not for the Gator. Any ideas?
   / Slip scoop for XUV #6
How about on of the snow pushers they sell that chain onto a Kubota BX loader....not sure of the brand but they are Diamond yellow color
   / Slip scoop for XUV #7
JCMSEVEN do you have a winch? I think you could weld a bucket bracket on the Deere plow subframe and use the winch to lift/lower. The plow subframe has 3 bolts that attach either the pivot bracket for 72" straight or V-plow assemblies, you could use these bolts to attach a bracket for the bucket. I have a lot of rock and have bent the pivot bracket, the hinge frame, but never any problem with the sub-frame, so the subframe is pretty strong. The subframe attaches with just 2 pins that go through existing holes in the XUV's frame. I do not believe the hydraulic plow lifter would be of any use, too weak to lift even a small loaded bucket.
   / Slip scoop for XUV #8
I agree, we have the old 620i XUV (same as HPX except rear suspension) and we find it incredibly useful.
   / Slip scoop for XUV #9
BTW- the Deere part number for the implement lift frame is BM24344. This is a kit that includes the frame and mounting pins.
Swict 78" Bucket (A57149)
Swict 78" Bucket...
2011 JACK COUNTY 130BBL VAC TRAILER (A58214)
2011 JACK COUNTY...
DOOSAN  G25 GENERATOR (A58216)
DOOSAN G25...
17101 (A55851)
17101 (A55851)
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
